ssid not displayed
Hi I have a problem with a WLC 5508 the problem is that in one AP I didn´t see one SSID but I could see the SSID for the
guest users.
In the clientes I saw the SSID and them I didn´t see it so the clients couldn´t connect to the wireless, this onle happen in this AP.
for the moment I don´t know if all the clients couldn´t see the SSID or only happen with a specific clients.
Thanks....
VIP Collaborator
ssid not displayed
Azariel
What ID did you use for this WLAN? when you created you new WLAN the WLC ask for an ID, you must choose 1 to 16, if you choose any value > 16 the SSID is not broadcasted less you have some AP Groups
ssid not displayed
It´s the number 4.
VIP Collaborator
ssid not displayed
so... you're saying you can see this WLAN in ther AP's? just one doesn't? O you can see it at all?
SSID is enable? Broadcast is enable?
Rising star
ssid not displayed
Hello Azariel,
As per your query i can suggest you the following solution-
Configuring Fast SSID Changing
When fast SSID changing is enabled, the controller allows clients to move between SSIDs. When the client sends a new association for a different SSID, the client entry in the controller connection table is cleared before the client is added to the new SSID. When fast SSID changing is disabled, the controller enforces a delay before clients are allowed to move to a new SSID.
Hope this will help you.
Highlighted
ssid not displayed
I test in one client and I saw the SSID but in the next 4 seconds I didn´t see that SSID but the strange is that I can see another SSID that is in the same AP.
The SSID is enable and broadcast in enable too.
Thanks...
Ask the Expert- Firepower configuration & troubleshooting
