Community Live- Understanding How Multicast Works with Cisco
268
Beginner
Syslog about "%CAPWAP-3-INVALID_RET_CODE"
I got a message but I couldn't understand the problem.
All assistance will be greatly appreciated.
Syslog message generated from device : *%CAPWAP-3-INVALID_RET_CODE: 1 wcm:  Invalid result code 3. Failed to Process DTLS packet
Angela
4 REPLIES 4
Highlighted
Beginner
Hello,Thanks for posting your
Thanks for posting your issue.
Kindly let me know the issue exactly you are facing with CML.
Are you able to run the simulation successfully or not.
Thanks and Regards,
Bikash
Rising star
What is the WLC, code? Its an
What is the WLC, code? Its an error which signifies TLS setup failure ( tunnel ) b/w AP_WLC. Can you reboot WLC?
Beginner
Hello Saurav, Are you getting
Hello Saurav,
Are you getting this issue in Cisco Modeling Lab environment.
Thanks and Regards,
Bikash
Beginner
I changed the category to
I changed the category to "wireless" yesterday.
Content for Community-Ad
August's Community Spotlight Awards
