11-01-2017 09:27 PM - edited 07-05-2021 07:47 AM
We have a typical SSO WLC architecture in our network and a configured syslog server. But from the past few days, we are receiving logs from the Hot-standby WLC instead of the active primary WLC.
Also, the logs from the hot-standby WLC are not full in size, they are the minimal ones.
Our WLC's are on version 8.2.151.0.
Can anyone help?
11-01-2017 10:13 PM
That is expected, the Secondary WLC will communicate to Syslog & NTP server using the Redundancy-management IP.
However, it shouldn't affect the Primary WLC syslog logging details. Please double confirm that you don't see any messages on Syslog from the Primary WLC?
Divya
11-01-2017 11:41 PM
yeah, i agree to you that the secondary should also send the logs.
The only problem here is we are not receiving a single log file from the primary one.
We also tested configuring a local syslog server (my machine) and configuring it in the primary WLC.
Unfortunately, the logs which were fetched on my machine through tftps were from the secondary one.
11-01-2017 11:59 PM
Hmmm.. That's weird!
Both of the Controllers are configured for the same Syslog server? Is the logging level is configured as required?
Was there any recent upgrade/changes on WLC?
Divya
11-02-2017 01:17 AM
11-02-2017 01:32 AM
Alright!
Please delete and re-add the same Syslog server. Enable the logging level as "7" and then check.
Divya
