10-08-2014 05:20 AM - edited 07-05-2021 01:41 AM
Hello I have 2 WLC in my company, 1 is backup of the other one.
When i first connect the AP to the network, it is getting attached to the backup one, how can i cange it?
However, the AP is connected in the same network of my production WLC, also, when i ping "cisco-capwap-controller" it is getting the production AP, not the Bckp one.
How can i change it, and make my default WLC the production one and not the bck up one?
Tx,
B
10-08-2014 06:25 AM
Under High Availability tab of AP, paste the info of primary WLC name, IP and also the secondary WLC name, IP.
After configuration of this you will see that AP will join to Primary.
Check this post:
http://rscciew.wordpress.com/2014/01/22/ap-failover/
Dont forget to rate helpful posts
10-08-2014 06:30 AM
hello, thanks for this quick answer, but the problem is at the initial connection of the AP...
The first time i Connecte a blank AP, i want it to connect to the production WLC and not the Backup.
After, when i configure it, i agree with you, i need to setup the 'High Availablility" but at the very first connexion, how can the AP hit the right WLC?
10-24-2014 02:00 PM
if you use DHCP on a Switch or a Server then define option43 only for the primary Controller!!
Best Regards,
Mario
