09-16-2019 05:01 AM - edited 07-05-2021 11:00 AM
I have one remote site with 10pcs ap 1815I-E-K9,7 pcs joined controller 5520 but 3 pcs not joined although these 3 pcs are pingable from wlc,support please
09-16-2019 05:04 AM
can you console to the non working AP and paste the bootp process logs.
also paste the output of these commands:
sh sysinfo from WLV
sh version from AP
Dont forget to rate helpful posts
09-16-2019 05:15 AM
09-16-2019 05:54 AM
Whihc country code you configured on WLC ? any europian domain!!!
Check if date & time is corerctly configured on WLC!
if above these points are are corerctly configured and still not joining then downgrade AP software to ap1g5-k9w8-tar.153-3.JD16.tar or Upgrade wlc to 8.5.151.0 and give a try.
