To Mobility Express Cisco 8.8.100
Dhikra Marghli
Level 5
Level 5
Hello
I convert from 8.3.111 AP  1815i CAPWAP  to moblity express 8.8.100
But i have a problem :
switch  layer 2 can ping to Cisco mobility express WLC  and my Laptop can pingto  Cisco mobility express WLC
but WLC moblity  express  can't ping   the   switch  ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent ,  i must to resolve this problem So ,
how i can reslove this   CME  that allow  ME ping to switch and laptop and i can get Web GUI   ?????????????
thanks in advance
67 Replies 67
Dhikra Marghli
Level 5
Level 5
Hello
thanks in advance
Try to reset the AP to factory defaults. Once it's booted (takes around 5-7 minutes) you should see an SSID where you can connect wirelessly to it.
I think the AP requires a valid DHCP IP address on the LAN for this.
Also, I suggest you upgrade to 8.8.111.0, as this fixed many other bugs.
See here for the manual: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/88/user_guide/b_ME_User_Guide_88/getg_started.html
I try to Upgrad to 8.8.111   but how i can reset cisco moblity Express to    factory defaults  per commande CLI ????????
so that allow me to upgrade to 8.8.11 !!
if i used this commande  yes or NO ???????  to rest this ME to factory defaults  !!!!
(Cisco Controller) > config ap unifiedmode <switch_name> <switch_ip_address>
i wait please you answer !!! thanks in adavance
You will find the information in the manual I linked you before regarding the upgrade.
For the factory default, check: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_21a_JA1/configuration/guide/scg12421aJA1/scg12421aJA1-chap4-first.html#wp1103218
Use the first variant with the Mode Button, that's the easiest.
i don't find this commande on Cisco Moblity express 8.8.100
i send you  a file  in 1815i
i don't find this command  erase nvram ?????,
How i can i would  reset the AP1815i  to factory defaults  that allow me upgrade !!
For a start, just reset it and get it working with your current 8.8.100.0 release. That should work.
To reset it (do the second variant):
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1815/quick/guide/ap1815igetstart.html#pgfId-79276
o use the mode button, press, and keep pressed, the mode button on the access point during the boot cycle. Wait until the status LED changes to Amber. During this, the AP console shows a seconds counter, counting the number of seconds the mode button is pressed. Then:
* To reset the AP to the default factory-shipped configuration, keep the mode button pressed for less than 20 seconds. The AP configuration files are cleared.
This resets all configuration settings to factory defaults, including passwords, encryption keys, the IP address, and the SSID. However, the regulatory domain provisioning is not reset.
* To clear the AP internal storage, including all configuration files and the regulatory domain configuration, keep the mode button pressed for more than 20 seconds, but less than 60 seconds.
The AP status LED changes from Amber to Red, and all the files in the AP storage directory are cleared.
If you keep the mode button pressed for more than 60 seconds, the mode button is assumed faulty and no changes are made.
I followed the steps but the file is not delete and   but the Led is red
show tech-support
---------------Show boot---------------
Primary Boot Image............................... 8.8.100.0 (default) (active)
Backup Boot Image................................ 8.8.111.0
---------------show time---------------
Time............................................. Mon Dec 10 14:19:35 2018
Timezone delta................................... 0:0
Timezone location................................
---------------Show Inventory---------------
System Inventory
Burned-in MAC Address............................ 78:0C:F0:DB:2A:80
Maximum number of APs supported.................. 50
---------------Show udi---------------
NAME: "Mobility Express" , DESCR: "Cisco Aironet 1815 Series Mobility Express"
PID: AIR-AP1815I-I-K9, VID: V01, SN: FGL2221B268
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.8.100.0
OUI File Last Update Time........................ N/A
System Name...................................... controller
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2489
IP Address....................................... 192.168.1.122
Last Reset....................................... 0: unknown
System Up Time................................... 0 days 0 hrs 15 mins 46 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 30
Memory Average Usage............................. 30
CPU Current Usage................................ 1
CPU Average Usage................................ 1
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
---------------Show advanced backup-controller---------------
--More-- or (q)uit
Cisco Controller) >show interface summary
Number of Interfaces.......................... 2
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management 1 untagged 192.168.1.122 Static Yes No
virtual N/A N/A 192.0.2.1 Static No No
Cisco Controller) >config ap unifiedmode controller 192.168.1.122
Warning! Sending config unifiedmode to all APs will cause the WLC to be rebooted.
Are you sure you want to continue? (y/n) y
Cisco AP/SWITCH name is invalid.
i would this AP cisco Moblity Express 8.8.100 upgrade to 8.8.111 .. ?
How do that ??,,,,,
Don't do the upgrade yet, first get it working and serving wireless clients.
First, please show the output of:
Show version
This should show if you are running a Mobility Express image (which I think you are).
It should look similar to this:
cisco AIR-AP1852E-UXK9 ARMv7 Processor rev 0 (v71) with 997184/525160K bytes of memory.
Processor board ID RFDP2BCR021
AP Running Image : 8.2.100.0
Primary Boot Image : 8.2.100.0
Backup Boot Image : 8.1.106.33
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
0 Gigabit Ethernet interfaces
0 802.11 Radios
Radio FW version . 1401b63d12113073a3C08aa67f0c039c0
NSS FW version : NSS.AK.1.0.c4-0Z026-E_cust C-1.24160
If the part "AP Configuration" is not the same as above (Not Mobility Express Capable) follow this guide here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_cisco_mobility_express_8_8/b_cisco_mobility_express_8_8_chapter_01.html
But I think yours is ME Capable. In that case you should now see a new wireless SSID named CiscoAirProvision.
you can acces for remote access  for this AP 1815i Moblity expres with Team viewer  ???????,
i need your answer Yes or No  to accpet remote acces
i give you ID .. please help me for this 1815i that allow me to upgrade to 8.8.111
because the   config is remain and not delete ???,,
For a software upgrade, you require a TFTP server in the same LAN segment as the accesspoint, plus you require the update.
Do you have both?
If yes, login via console to the AP and run the following command:
ap-type mobility-express tftp://IP-address-of-your-tftp-server/AIR-AP1815-K9-ME-8-8-111-0.tar
reset system
The above line is only in the case your AP is NOT running a mobility express capable image.
If it is running Mobility Express Capable Image, then the upgrade is:
transfer download datatype ap-image
transfer download ap-images mode tftp
transfer download ap-images serverIp
transfer download ap-images imagePath AIR-AP1815-K9-ME-8-8-111-0.zip
transfer download start
reset system
Mind the different images you require, depending on the mode the AP is working in (show version).
No I can't help you with team viewer from here, sorry.
I try  there command  and tell you ASAB ....
thanks in advance
cisco 1815i Cisco Moblity EXPRESS IS now  Led id Red now after reset this AP 1815i ????????, as you tell me
Cisco Controller) >show tech-support
But  i would this Mobilty 8.8.100 convertir to AP CAPWAP 8.3.111  as default previous :: my Goal  ?,,,
so how i can do  after i used reset and now the 1815i is led red !!!!!
Please show the output of:
show version
(Cisco Controller) >show ?
802.11a Display 802.11a configuration.
802.11b Display 802.11b configuration.
802.11h Display 802.11h configuration.
aaa Displays AAA related information
acl Display system Access Control Lists.
advanced Display Advanced configuration and statistics.
ap Display AP Configuration.
arp Display ARP cache.
assisted-roaming Display Assisted Roaming and 802.11k configuration.
atf Display ATF configuration/statistics
auth-list Display AP authorization list.
avc Display AVC Configuration/Statistics.
band-select Display Aggressive Load Balancing configuration.
boot Displays the default boot image.
buffers Display pmalloc buffer utilization.
cac Show Call-Admission-Control details
call-control Display Call-control information
cdp Display CDP information
certificate Display SSL Certificate Configuration.
client Displays active clients.
cloud-services Displays the Cloud Server Configuration
coredump Displays Core Dump Summary
--More-- or (q)uit
country Display the configured countries.
cpu Display current CPU usage information.
custom-web Display Web Authentication customization information.
database Show local database configuration.
debug Display enabled debugs.
dhcp Display the dhcp server configuration.
dtls Display the DTLS server status.
dx Displays DX related information
emweb Displays emweb related information.
eventlog Display event log entries.
exclusionlist Display exclusion-list.
flexconnect Display controller flexconnect information.
flow Display flow Configuration.
fragDetails Display CAPWAP Control Fragment Reassembly Counters.
guest-lan Display Guest LAN Configuration.
icons Show icon filename and its information.
interface Display system interfaces.
invalid-config Display Invalid Config.
inventory Display vital product data.
ipv6 Display IPv6 information.
ldap Displays LDAP information.
linktest Shows the configured frame size and number of frames for linktest.
load-balancing Display Aggressive Load Balancing configuration.
--More-- or (q)uit
local-auth Display Local EAP Authentication information.
location Display Location based System information
logging Display logger parameters and buffer contents.
loginsession Display login session info.
macfilter Display MAC filtering configuration.
mdns Displays mDNS information
media-stream Display Multicast-direct Configuration State
memory Display system memory usage statistics.
mesh Show mesh configuration.
mgmtuser Display local management user accounts.
mob-exp Display infomation specific to MoblityExpress
mobility Display Mobility Management Configuration.
msglog Display message log entries.
netuser Display local network user accounts.
network Display configuration for inband connectivity.
nmheartbeat Displays Network Manager Heart Beat Summary
nmsp Displays data for NMSP protocol between controller and Location Server.
ntp-keys Display the system time.
oeap-acl Display OEAP Access Control Lists.
pi-ip-address Display SNMP community entries.
pmk-cache Display information about the PMK cache.
policy Displays detailed information of a policy
port Display port mode and settings; display port status.
--More-- or (q)uit
process Display CPU and memory usage per process.
profiling Display local device classification information.
qos Display qos information (queue length)
queue-info Display system Message Queue Information.
radius Displays RADIUS information.
remote-lan Display remote LAN Configuration.
reset Display scheduled system reset parameters.
rf-profile Configures RF Profile parameters.
rfid Shows the RFID tag tracking information
rogue Displays Rogue AP and Client information.
route Display configured route
rules Display active internal firewall rules.
run-config Display running configuration.
running-config Display running configuration.
serial Display EIA-232 parameters and serial port inactivity timeout.
service Display service information.
sessions Display cli session configuration information.
snmpcommunity Display SNMP community entries.
snmpengineID Display SNMP v3 EngineId.
snmptrap Display SNMP trap port number and trap receiver entries.
snmpv3user Display SNMP v3 user entries.
snmpversion Display SNMP v1/v2/v3c status(enabled or disabled).
split-tunnel Show the configured split tunnel network lists.
--More-- or (q)uit
stats Display port and switch statistics.
switchconfig Display parameters that apply to the switch.
sysinfo Display system information including system up time.
syslog Displays the state of system syslog.
system Display system information
tacacs Displays TACACS+ information.
tech-support Display system resource information.
telemetry Display configuration for telemetry connectivity
time Display the system time.
trapflags Display the value of trap flags that apply to the switch.
traplog Display snmp trap records.
trapstats Display snmp trap statistics.
tunnel Tunneling protocols
u3-interface Shows the U3-Interface data
udi Display UDI for the controller
wgb Displays active work-group bridges (WGB).
wlan Display WLAN Configuration.
wps Displays WPS Configuration.
secure-tunnel Displays secure tunnel information
icap Displays Intelligent capture configuration
show version does not exist !!!!!!!!!!!?,,,
