To Mobility Express Cisco 8.8.100
Dhikra Marghli
Level 5
Level 5
Hello
I convert from 8.3.111 AP  1815i CAPWAP  to moblity express 8.8.100
But i have a problem :
switch  layer 2 can ping to Cisco mobility express WLC  and my Laptop can pingto  Cisco mobility express WLC
but WLC moblity  express  can't ping   the   switch  ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent ,  i must to resolve this problem So ,
how i can reslove this   CME  that allow  ME ping to switch and laptop and i can get Web GUI   ?????????????
thanks in advance
67 Replies 67
How i can give you  full boot console output, ????????, what command used to give output as you like !!!?,,,,,,,,,,
Please  patoberli   ,
1) ++ I ask you for the first time and last time to access remote by team viewer to help me and it is urgent project, it must be completed this week i need your ok yes or no !!
2) ++ cisco AP1815i Moblity express 8.8.100, I had to explain my problem at the beginning, switch can ping ME but ME can not ping and not broadcast SSID and can't get to Web GUI  ..i reset as described previously but it Led red remain Red is blinking ..
so i think try to acces remote via team viwer for first time or help me for problem Led red and convertir to AP CAPWAP normal with privious software 8.3.111
my goal : this AP1815i with 8.8.100 convert to AP CAPWAP normal with privious software 8.3.111 because i used onther AP to be 8.8.111 last version
so i wait you answer and your help definitive
thanks in advance
Thanks  in advance
Please  patoberli   ,
thanks in advance
i wait you ok for remote access or give me what command  used to give full boot console output  1815i Moblity Express  as that controller !!!!
that resolve all problem !!!
Sorry I don't do remote access.
For the boot log, you require a console cable, attached to a serial port on a pc. One is connected you simply power reset the AP and you will see all the boot messages.
I will be back online tomorrow.
show version
does not find as command in controller 1815i !!!
so what command you nedd and i need to acces for remote , please , i need your ok for to  morrow !!
Configured Country............................... US - United States
1.  Country Code configured on the AP is US.  The AP has a Regulatory Domain of -I for Tunisia.
2.  Why so hell-bent with 8.8.100.0?  I wouldn't touch that version for production. Unless there is critical requirement, go with 8.5.140.0
How i can correct Led red for cisco ME 1815i  ????????,
please , this project wireless urgent
please help me for this probem !!!
cisco 1815i Cisco Moblity EXPRESS IS now  Led id Red now after reset this AP 1815i ????????, as you tell me
Cisco Controller) >show tech-support
---------------Show boot---------------
Primary Boot Image............................... 8.8.100.0 (default) (active)
Backup Boot Image................................ 8.8.111.0
But  i would this Mobilty 8.8.100 convertir to AP CAPWAP 8.3.111  as default previous :: my Goal  ?,,,
so how i can do  after i used reset and now the 1815i is led red !!!!!
why  now this 1815i ME is led RED and not other coloer ??????????
why now this 1815i ME is red Led ??????????,
now ciso 1815i Mobility Express led is red after i do reset as you tell me !!!
But  i would  this 8.8.100 convertir to 8.3.111 as default . so how i can do that ???????  convertir to AP capwap as I bought
Problem , now led is red not green but configuration remain ????????!!!!
you can acces for remote access  for this AP 1815i Moblity expres with Team viewer  ???????,
i need your answer Yes or No  to accpet remote acces
i give you ID .. please help me for this 1815i 8.8.100  that allow me convertir to AP CAPWAPA  ...
i would convertir to AP normal as first
because the   config is remain and not delete ???,,
Enter User Name (or 'Recover-Config' this one-time only to reset configuration to factory defaults )
what i  put ???????,,
i put " Recover-Config "   or  name user ??????,,  allow upgard to 8.8.111
please  you can answer me !! i wait for your answer to help !!
thanks in advance
