To Mobility Express Cisco 8.8.100
Dhikra Marghli
Level 5
Level 5
Hello
I convert from 8.3.111 AP  1815i CAPWAP  to moblity express 8.8.100
But i have a problem :
switch  layer 2 can ping to Cisco mobility express WLC  and my Laptop can pingto  Cisco mobility express WLC
but WLC moblity  express  can't ping   the   switch  ni Laptop and not broadcast SSID and can't get to Web GUI
anyone had this kind of issue with AP 1815i CME?
Urgent ,  i must to resolve this problem So ,
how i can reslove this   CME  that allow  ME ping to switch and laptop and i can get Web GUI   ?????????????
thanks in advance
67 Replies 67
(Cisco Controller) >show sysinfo Manufacturer's Name.............................. Cisco Systems Inc. Product Name..................................... Cisco Controller Product Version.................................. 8.8.100.0 OUI File Last Update Time........................ N/A System Name...................................... controller System Location.................................. System Contact................................... System ObjectID.................................. 1.3.6.1.4.1.9.1.2489 IP Address....................................... 192.168.1.122 Last Reset....................................... 1: reload command System Up Time................................... 0 days 0 hrs 18 mins 49 secs System Timezone Location......................... System Stats Realtime Interval................... 5 System Stats Normal Interval..................... 180 Configured Country............................... US - United States State of 802.11b Network......................... Enabled State of 802.11a Network......................... Enabled Number of WLANs.................................. 1 --More-- or (q)uit Number of Active Clients......................... 0 OUI Classification Failure Count................. 0 Memory Current Usage............................. 30 Memory Average Usage............................. 30 CPU Current Usage................................ 1 CPU Average Usage................................ 1 Flash Type....................................... Compact Flash Card Flash Size....................................... 1073741824 Burned-in MAC Address............................ 78:0C:F0:DB:2A:80 Maximum number of APs supported.................. 50 System Nas-Id.................................... WLC MIC Certificate Types........................ SHA1/SHA2
I see. You are connected to the Controller part of the AP, that means mobility express is running.
Is the LED static red or blinking?
Static would be very bad, because that means a corrupted image, which I find hard to believe, as the AP seems to be running.
If it's blinking red, then the wrong country is selected.
Can you please post the full boot console output?
If it's blinking red  :=======> Now
How i Can  please post the full boot console output?   what command used ??????,,
(Cisco Controller) >show tech-support
---------------Show boot---------------
Primary Boot Image............................... 8.8.100.0 (default) (active)
Backup Boot Image................................ 8.8.111.0
---------------show time---------------
Time............................................. Mon Dec 10 15:01:45 2018
Timezone delta................................... 0:0
Timezone location................................
---------------Show Inventory---------------
System Inventory
---------------Show udi---------------
NAME: "Mobility Express" , DESCR: "Cisco Aironet 1815 Series Mobility Express"
PID: AIR-AP1815I-I-K9, VID: V01, SN: FGL2221B268
---------------Show sysinfo---------------
System Information
Last Reset....................................... 0: unknown
System Up Time................................... 0 days 0 hrs 12 mins 6 secs
--More-- or (q)uit
CPU Current Usage................................ 0
CPU Average Usage................................ 0
---------------Show advanced backup-controller---------------
--More-- or (q)uit
Backup Controller Configuration
AP primary Backup Controller ....................
AP secondary Backup Controller ..................
---------------Redundancy Information---------------
Redundancy Mode ................................. SSO DISABLED
Local State...................................... ACTIVE
Peer State....................................... N/A
Unit............................................. Primary
Unit ID.......................................... 78:0C:F0:DB:2A:80
Redunadancy State................................ N/A
Mobility MAC..................................... 78:0C:F0:DB:2A:80
Redundancy Management IP Address................. 0.0.0.0
Peer Redundancy Management IP Address............ 0.0.0.0
Redundancy Port IP Address....................... 0.0.0.0
Peer Redundancy Port IP Address.................. 169.254.0.0
AP Bundle Information not supported.
--More-- or (q)uit
---------------Show Interface ---------------
Interface Configuration
Interface Name................................... management
MAC Address...................................... 00:00:5e:00:01:01
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.1.254
IP Address Type.................................. Static
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::7a0c:f0ff:fedb:2a80/64
STATE ........................................... NONE
Primary IPv6 Address............................. ::/128
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
STATE ........................................... CREATING
VLAN............................................. 10
Quarantine-vlan.................................. 0
Physical Port.................................... 1
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. Unconfigured
what command used to give you as you like ???????,
For the boot log output you have to attach a console cable, open a serial connection and then reboot the AP.
Regarding the country, you have an -I- model AIR-AP1815I-I-K9, that means you have to select a country where the -I- is permitted, for example Egypt or Israel (I assume you live in such a country?). You find the full list of countries here:
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
After that the red blinking should stop.
The command for Israel including a full reboot:
config country IL
save config
reset system
we have  from Tunisia
so what i put  as command !!!!!!!!!
I am from Tunisia !
i put Israil is better ?????????,
to stop red !!
please , give me the answer about that !!
(Cisco Controller) >show country
Configured Country............................. US - United States
Configured Country Codes
US - United States............................. 802.11a Indoor,Outdoor / 802.11b / 802.11g
i fault for that
so how i can coorecte to 1815i ???,
I am from Tunisia but what i can put for better : Israil ?????,
For Tunisia it's:
config country TN
IT better put Tunsia or Israil because code TN don't find !!!
thanks very much to help but i can put is better to stop led RED
thanks very much to help but  what  i can put is better  ???????  to stop led RED
If you select one of those country codes and reset the AP, the red LED should stop and it should offer you the SSID to configure it via wireless.
(Cisco Controller) >config country IL
Changing country code could reset channel & RRM grouping configuration.
If running in RRM One-Time mode, reassign channels after this command.
Check customized APs for valid channel values after this command.
Are you sure you want to continue? (y/n) y
Disable 802.11a and 802.11b networks prior to configuring country code.
what i can do config !! what i can put ????,
config 802.11a disable
config 802.11b disable
config country IL
config 802.11a enable
config 802.11b enable
save config
reset system
[edit]
Corrected commands.
i try thes command but Led red remain Red blinking !!!???????,
what is problem then ?????????
so how can  resolve problem Led red but is is runn 8.8.100
I don't know. I think I need now the full boot console output, as described previously.
