toplogy mesh wireless cisco : RAP and MAP
Dhikra Marghli
Level 5
Level 5
Hello
I have a question about toplogy mesh wireless cisco : RAP and MAP
i want to know if Toplogie mesh wirless is need is need controller hardware or  moblity express ME 1815i ???
i want link talk about the rules about mesh with AP 1815i moblity express ??
Thanks in advance
5 Accepted Solutions
Sandeep Choudhary
As per my knowledge...
Mobility Express doesn't support MESH.  Here you can see what is not supported:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn81mr2.html#pgfId-1319021
Dont forget to rate helpful posts
Sandeep Choudhary
Also check the link for new software which say Mesh mode not supported:
Check Table 9
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn88.html#ap-wave2
Mean that 1815 is not supported mode mesh
so what are the hardware AP supported mod mesh !!
thanks in advance
yes you need a hardware controller and APs.
check the list: https://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-0/design/guide/mesh80/Mesh_Network_Components.html
Cisco Indoor Mesh Access Points
Indoor mesh is available on the following access points:
802.11n
1040
1140
1260
802.11n+CleanAir
1600
2600
3500e
3500i
3600
802.11ac+CleanAir
1700
2700
3700
Outdorre APs:
example: 1500 series..1532, 1552, 1572
7 Replies 7
Sandeep Choudhary
mean that topolgy mesh need a controller haradware !!??  not moblity express !!
 so Toplogy mesh need  controller and access point !!
thanks in advance
Sandeep Choudhary
Check Table 9
thanks in advance
Thanks , i would to know  any  mode acces point work to mode mesh !!?,
thanks in adavnce
802.11n
1040
1140
1260
802.11n+CleanAir
1600
2600
3500e
3500i
3600
802.11ac+CleanAir
1700
2700
3700
Outdorre APs:
