10-01-2012 08:24 PM - edited 07-03-2021 10:45 PM
I try,but fail.how can I do it?
Sent from Cisco Technical Support Android App
10-01-2012 08:27 PM
ps,tplink 501 repeater to tp link 710n is normal.
10-02-2012 04:51 PM
DDD UP!
10-06-2012 12:36 AM
is there fellow?
10-16-2012 09:32 AM
Hello guoqiang.li
Thank you for your question.
However, the Small Business Support Community is limited to Cisco Small Business Products and the EA4500 is not a Cisco Small Business Product. The EA4500 is considered as a Cisco Home Product.
In the next link you will find the area that may help you further with your question.
http://homesupport.cisco.com/en-us/support/routers/EA4500
Best regards,
Diego Rodriguez
Cisco Small Business Community Engineer
11-15-2012 07:09 AM
can i use home support in android app?
