02-12-2020 10:22 PM - edited 07-05-2021 11:42 AM
we have installed many Cisco APs? In dem floor map I can see that many APs send with low transmit power. The users complain about low signal strenght. Where can I see the transmit power on the WLC gui and how can I change the transmit power only on one AP.
02-12-2020 10:27 PM
Normally RRM automatically assign the power level for APs but you can also set it statically.
Go to Wireless > 802.11a/n/ac or 802.11b/g/n >RRM >TPC and here you set fixed power levels.
Dont forget to rate helpful posts
02-12-2020 10:39 PM
Is this a global Configuration for all APs? I will change the Transmit power only on the AP wich has low transmit power.
02-12-2020 11:06 PM - edited 02-12-2020 11:12 PM
yes it is global config..
But you can also manually change on each AP as well.
Go to Wireless > Access Points > Radios > (802.11a/n/ac or 802.11b/g/n > Click on Blue drop down arrow far right , here you can change the Tx Power of each AP by using Custom method.
02-13-2020 01:33 AM
Depending on the number of AP's and their physical location it is usually better to create RF-Profiles and group the AP's logically. That way you are not relying on the global only power settings.
