01-13-2012 10:24 AM - edited 07-03-2021 09:22 PM
I have 2 3502I WAP's in my London office that i'm trying to register to our Amsterdam 4402 WLC. They were able to successfully pull DHCP from a local switch, including option 43, and did register with my controller yesterday. As per the normal process, the controller pushed an updated image to each, and the WAP's reboot. After the reboot, they are stuck in an endless loop of trying to call the ap-manager interface, not the Management interface, so are failing to register.
As of now, i'm at a loss as to how to correct this. Is there a compatibility issue with the image that was pushed? Is there a way to push a different image, with the correct IP?
Please see the attachment for the repeating logs on the CLI of one of the WAP's.
Any ideas/help would be greatly appreciated.
Jeff Bull
Solved! Go to Solution.
01-13-2012 03:56 PM
Also... are these ap's local to where the wlc is at or you trying to do this over the WAN?
01-13-2012 03:57 PM
Over the WAN. The AP's are in London, controller is in Amsterdam.
01-13-2012 03:57 PM
Yes, both ap-manager & management interfaces are in the same IP subnet. I currently have 9 access points in Amsterdam (same location as the controller) registered to the controller successfully.
01-13-2012 03:59 PM
Okay... well if you are doing option 43 and it is working they should find the wlc. Can you post the whole output of the ap join process if you can? I want to make sure it does see the option and is pointing to the WLC.
01-13-2012 04:04 PM
Sure thing Scott...
I've included the logs from the start of the last reboot (after issues the clear capwap private command)
r WRDTR,CLKTR: 0x84000800 0x00000000
r RQDC ,RFDC : 0x80000032 0x00000256
using eeprom values
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x84000800, 0x00000000
RQDC, RFDC : 0x80000032, 0x00000256
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
64bit PCIE devices
PCIEx: initialization done
flashfs[0]: 36 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31739904
flashfs[0]: Bytes used: 8303104
flashfs[0]: Bytes available: 23436800
flashfs[0]: flashfs fsck took 13 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 28:94:0f:c1:17:e3
Ethernet speed is 100 Mb - FULL duplex
Loading "flash:/ap3g1-k9w8-mx.124-23c.JA2/ap3g1-k9w8-mx.124-23c.JA2"...################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/ap3g1-k9w8-mx.124-23c.JA2/ap3g1-k9w8-mx.124-23c.JA2" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:20 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 36 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31481856
flashfs[1]: Bytes used: 8303104
flashfs[1]: Bytes available: 23178752
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0 present 8364B 8000 B8020000 0 B8030000 10
Radio1 present 8364B 8000 B0020000 0 B0030000 C
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-CAP3502I-A-K9 (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FGL1551S4ZS
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from reload
LWAPP image version 7.0.116.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 28:94:0F:C1:17:E3
Part Number : 73-12175-05
PCA Assembly Number : 800-32268-05
PCA Revision Number : A0
PCB Serial Number : FOC1548586P
Top Assembly Part Number : 800-32891-01
Top Assembly Serial Number : FGL1551S4ZS
Top Revision Number : A0
Product/Model Number : AIR-CAP3502I-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:09.490: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:09.500: *** CRASH_LOG = YES
*Mar 1 00:00:09.500: 64bit PCIE devicesSecurity Core found.
Base Ethernet MAC address: 28:94:0F:C1:17:E3
*Mar 1 00:00:12.409: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:13.212: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar 1 00:00:13.441: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.911: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar 1 00:00:15.964: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar 1 00:00:15.980: status of voice_diag_test from WLC is false
*Mar 1 00:00:18.081: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:18.081: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:11:54.034: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 1 00:11:54.047: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:11:54.047: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:11:54.207: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:11:54.972: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:11:55.047: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:11:55.047: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:12:04.078: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.208.237, mask 255.255.255.248, hostname AP2894.0fc1.17e3
*Mar 1 00:12:12.940: status of voice_diag_test from WLC is false
*Mar 1 00:12:12.997: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:12:17.743: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:12:17.835: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:12:17.932: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:12:18.753: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:12:18.753: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar 1 00:12:18.851: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.170.2.4)
*Mar 1 00:12:24.019: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.170.29.10 obtained through DHCP
*Jan 14 00:19:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:19:39.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:19:39.556: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:19:39.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:19:39.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:19:44.558: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:19:44.750: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:19:44.766: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:19:44.766: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:19:44.766: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:19:44.819: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:19:44.882: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 14 00:19:44.882: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 14 00:19:44.901: status of voice_diag_test from WLC is false
*Jan 14 00:19:55.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:19:55.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:19:55.556: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:19:55.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:19:55.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:20:00.558: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:00.737: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:20:00.756: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:20:00.756: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:20:00.756: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:20:00.813: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:20:00.879: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 14 00:20:00.879: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 14 00:20:00.895: status of voice_diag_test from WLC is false
*Jan 14 00:20:11.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:11.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:20:11.559: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:11.559: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:11.559: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:20:11.805: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:20:11.827: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:20:11.827: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:20:11.827: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:20:11.880: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:20:11.962: status of voice_diag_test from WLC is false
*Jan 14 00:20:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:22.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:20:22.556: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:22.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:22.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:20:22.802: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:20:22.824: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:20:22.824: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:20:22.824: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:20:22.877: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:20:22.959: status of voice_diag_test from WLC is false
*Jan 14 00:20:33.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:33.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:20:33.556: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:33.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:33.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:20:38.558: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:38.737: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:20:38.756: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:20:38.756: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:20:38.756: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:20:38.810: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:20:38.873: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 14 00:20:38.873: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 14 00:20:38.882: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 14 00:20:38.891: status of voice_diag_test from WLC is false
*Jan 14 00:20:48.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:48.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:20:48.556: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:20:48.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:20:48.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:20:48.805: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:20:48.827: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:20:48.827: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:20:48.827: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:20:48.880: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jan 14 00:20:48.909: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 14 00:20:48.909: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 14 00:20:49.862: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 14 00:20:49.871: status of voice_diag_test from WLC is false
*Jan 14 00:20:49.871: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 14 00:20:49.881: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 14 00:20:49.890: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 14 00:20:49.906: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 14 00:21:00.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:21:00.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 14 00:21:00.553: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.170.29.9 peer_port: 5246
*Jan 14 00:21:00.556: %CAPWAP-5-SENDJOIN: sending Join Request to 10.170.29.9
*Jan 14 00:21:00.556: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 14 00:21:00.742: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Jan 14 00:21:00.764: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.170.29.9
*Jan 14 00:21:00.764: %DTLS-5-PEER_DISCONNECT: Peer 10.170.29.9 has closed connection.
*Jan 14 00:21:00.767: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.170.29.9:5246
*Jan 14 00:21:00.880: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 14 00:21:00.880: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 14 00:21:00.890: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jan 14 00:21:00.899: status of voice_diag_test from WLC is false
*Jan 14 00:21:00.899: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jan 14 00:21:00.909: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 14 00:21:00.918: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jan 14 00:21:00.934: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
01-13-2012 04:07 PM
This is a US AP…. Is it the same country code for out there?
01-13-2012 04:12 PM
Bought the AP from a UK vendor, but if there's a way to change the country code on it, I can do that
01-13-2012 04:14 PM
You can’t change the country code on the AP, you can just add the country code to the WLC. So is that the wrong part number?
01-13-2012 03:57 PM
Controller is now running 7.0.116.0, and the 3502I's have received the new code, but are right back to where I started;
Hmmmm ... so it can "join" intially. Wierd.
Can you console into the WAP and enter the command "clear capwap private" and reboot again?
Another thing, you have a 4402. So how many WAPs can you 4402 support (25?) and how many are currently joined to this unit?
01-13-2012 04:01 PM
When the code on the AP's was outdated, and they were at factory settings, they would register and the controller would push out the new code. After the reboot, that's when connectivity no longer worked.
Just issued the "clear capwap private" command.... the AP i'm testing with is rebooting now.
01-13-2012 04:02 PM
Hi jeff,
thanks for the quick response.
01-13-2012 04:03 PM
Okay… you should see in the log the issue hopefully. Or else you can manually enter the ip address of the wlc.
01-13-2012 04:13 PM
It's a 4402, with a 12 AP license. Currently, there are only 9 AP's registered to it.
01-13-2012 04:15 PM
Hi Jeff,
Did my recommendation worked???? I'm confused because your thread has been marked as "Answered".
01-13-2012 04:17 PM
Leolaohoo,
I ran the command, but still the same result.
And no, my issue still exists.
