12-14-2013 10:04 AM - edited 07-04-2021 01:25 AM
I have recently been tasked with upgrading our old Autonomous APs to LWAPs. We have a 5508 WLC at our Virtual Co-Lo and I am using Flexconnect to accomadate local switching and dhcp at our sites. I have upgraded over 50 APs and joined them to the controller. These include only 1130AG and 1240AG models. However they are working flawlessly and staying connected to the controller. The issue I'm having is with a new batch of 2600 series APs staying connected to the controller. I have attempted to do research into what may be causing the disconnects but have yet to find a solution. I am using DNS to resolve the CAPWAP & LWAPP queries from the APs to the controller accross our WAN. In reading other posts I thought it may be an issue with packets getting dropped but have had our Vendor who manages Sonicwalls at both ends of the WAN confirm for me there is no packet loss. Below are logs I gathered using puttty from the AP & WLC. Any help would be greatly appreciated.
AP I'm doing the testing on:
NAME: "AP2600", DESCR: "Cisco Aironet 2600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP2602I-A-K9 , VID: V01, SN: FTX1740J8V1
WLC in question:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.112.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... wificontroller
System Location.................................. Corp
System Contact................................... Net Engineer
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.250.32.8
Last Reset....................................... Software reset
System Up Time................................... 190 days 3 hrs 34 mins 24 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
--More-- or (q)uit
Internal Temperature............................. +38 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 14
Number of Active Clients......................... 71
Burned-in MAC Address............................ C8:9C:1D:8C:52:E0
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 100
Here is the output that keeps on occuring as the AP joins the WLC for a brief time and then changes to standalone mode
WT-4thFlr-AP3#
*Dec 14 15:42:04.419: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 3)
*Dec 14 15:42:11.443: %EVT-4-WRN: Write of flash:/event.capwap done
*Dec 14 15:42:11.483: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Dec 14 15:42:11.487: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Dec 14 15:42:11.487: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.250.32.8:5246
*Dec 14 15:42:11.571: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Dec 14 15:42:21.575: %CAPWAP-3-ERRORLOG: Selected MWAR 'wificontroller'(index 0).
*Dec 14 15:42:21.575: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 14 15:42:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.250.32.8 peer_port: 5246
*Dec 14 15:42:14.303: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.250.32.8 peer_port: 5246
*Dec 14 15:42:14.303: %CAPWAP-5-SENDJOIN: sending Join Request to 10.250.32.8
*Dec 14 15:42:15.127: Starting Ethernet promiscuous mode
*Dec 14 15:42:15.535: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Dec 14 15:42:15.667: ac_first_hop_mac - IP:10.1.2.250 Hop IP:10.1.2.250 IDB:BVI1
*Dec 14 15:42:15.667: Setting AC first hop MAC: 0017.c575.a23c
*Dec 14 15:42:15.855: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller wificontroller
*Dec 14 15:42:15.911: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Dec 14 15:42:15.911: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Dec 14 15:42:15.915: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration file
*Dec 14 15:42:15.915: %LWAPP-3-CLIENTERRORLOG: Switching to Connected mode
*Dec 14 15:42:23.639: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Dec 14 15:42:34.615: %CLEANAIR-6-STATE: Slot 0 disabled
*Dec 14 15:42:34.615: %CLEANAIR-6-STATE: Slot 1 disabled
*Dec 14 15:45:43.783: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 11)
*Dec 14 15:45:43.787: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Dec 14 15:45:43.787: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Dec 14 15:45:43.787: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.250.32.8:5246
*Dec 14 15:45:43.867: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Dec 14 15:45:53.867: %CAPWAP-3-ERRORLOG: Selected MWAR 'wificontroller'(index 0).
*Dec 14 15:45:53.867: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 14 15:45:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.250.32.8 peer_port: 5246
*Dec 14 15:45:46.315: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.250.32.8 peer_port: 5246
*Dec 14 15:45:46.315: %CAPWAP-5-SENDJOIN: sending Join Request to 10.250.32.8
*Dec 14 15:45:46.487: Starting Ethernet promiscuous mode
*Dec 14 15:45:49.903: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Dec 14 15:45:50.031: ac_first_hop_mac - IP:10.1.2.250 Hop IP:10.1.2.250 IDB:BVI1
*Dec 14 15:45:50.031: Setting AC first hop MAC: 0017.c575.a23c
Here are the results of debug capwap client event on the AP:
WT-4thFlr-AP3#debug capwap client event
CAPWAP Client EVENT display debugging is on
WT-4thFlr-AP3#
*Dec 14 15:54:58.335: %CAPWAP-3-EVENTLOG: Echo Interval Expired.
*Dec 14 15:54:58.335: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:54:58.335: %CAPWAP-3-EVENTLOG: Echo Request sent to 10.250.32.8
*Dec 14 15:54:58.343: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:54:58.343: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:54:58.343: %CAPWAP-3-EVENTLOG: Echo Response from 10.250.32.8
*Dec 14 15:55:08.000: %CAPWAP-3-EVENTLOG: Setting time to 15:55:08 UTC Dec 14 2013
*Dec 14 15:55:25.579: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:55:25.587: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:55:25.587: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:55:25.587: %CAPWAP-3-EVENTLOG: Wtp Event Response from 10.250.32.8
*Dec 14 15:55:25.827: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:55:25.835: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:55:25.835: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:55:25.835: %CAPWAP-3-EVENTLOG: Wtp Event Response from 10.250.32.8
*Dec 14 15:55:55.835: %CAPWAP-3-EVENTLOG: Echo Interval Expired.
*Dec 14 15:55:55.835: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:55:55.835: %CAPWAP-3-EVENTLOG: Echo Request sent to 10.250.32.8
*Dec 14 15:55:55.843: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:55:55.843: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:55:55.843: %CAPWAP-3-EVENTLOG: Echo Response from 10.250.32.8
*Dec 14 15:55:56.000: %CAPWAP-3-EVENTLOG: Setting time to 15:55:56 UTC Dec 14 2013
*Dec 14 15:56:25.735: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:56:25.743: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:56:25.743: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:56:25.743: %CAPWAP-3-EVENTLOG: Wtp Event Response from 10.250.32.8
*Dec 14 15:56:25.983: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:56:25.991: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:56:25.991: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:56:25.991: %CAPWAP-3-EVENTLOG: Wtp Event Response from 10.250.32.8
*Dec 14 15:56:55.991: %CAPWAP-3-EVENTLOG: Echo Interval Expired.
*Dec 14 15:56:55.991: %CAPWAP-3-EVENTLOG: Sending packet to AC
*Dec 14 15:56:55.991: %CAPWAP-3-EVENTLOG: Echo Request sent to 10.250.32.8
*Dec 14 15:56:55.999: %CAPWAP-3-EVENTLOG: Resetting reTransmissionCnt to 0
*Dec 14 15:56:55.999: %CAPWAP-3-EVENTLOG: Queue Empty.
*Dec 14 15:56:55.999: %CAPWAP-3-EVENTLOG: Echo Response from 10.250.32.8
*Dec 14 15:56:56.000: %CAPWAP-3-EVENTLOG: Setting time to 15:56:56 UTC Dec 14 2013
Here are the results of debug capwap client packet detail:
WT-4thFlr-AP3#
*Dec 14 15:59:01.823: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:01.823: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:01.823: Msg Type : CAPWAP_ECHO_REQUEST
*Dec 14 15:59:01.823: Msg Length : 0
*Dec 14 15:59:01.823: Msg SeqNum : 44
*Dec 14 15:59:01.823: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:01.831: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:01.831: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:01.831: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:01.831: Msg Type : CAPWAP_ECHO_RESPONSE
*Dec 14 15:59:01.831: Msg Length : 15
*Dec 14 15:59:01.831: Msg SeqNum : 44
*Dec 14 15:59:01.831: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 11
*Dec 14 15:59:01.831: Vendor Identifier : 0x00409600
IE : UNKNOWN IE 151
*Dec 14 15:59:01.831: IE Length : 5
*Dec 14 15:59:01.831: Decode routine not available, Printing Hex Dump
52 AC 80 46 00
*Dec 14 15:59:01.831: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:20.931: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:20.931: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:20.931: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:20.931: Msg Type : CAPWAP_CONFIGURATION_UPDATE_REQUEST
*Dec 14 15:59:20.931: Msg Length : 93
*Dec 14 15:59:20.931: Msg SeqNum : 38
*Dec 14 15:59:20.931: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 89
*Dec 14 15:59:20.931: Vendor Identifier : 0x00409600
IE : RRM_NEIGHBOR_CTRL_PAYLOAD
*Dec 14 15:59:20.931: IE Length : 83
*Dec 14 15:59:20.931: Decode routine not available, Printing Hex Dump
00 0A FA 20 08 01 F4 00 07 0A FA 20 08 03 00 01
01 00 3C 00 B4 2E 06 2E E7 B4 94 51 B2 C7 79 25
22 FD BE 04 F6 00 00 00 00 00 00 00 00 4F 50 52
53 2D 57 69 46 69 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 01 06 0B
01 01 01
*Dec 14 15:59:20.931: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:20.931: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:20.931: Msg Type : CAPWAP_CONFIGURATION_UPDATE_RESPONSE
*Dec 14 15:59:20.931: Msg Length : 8
*Dec 14 15:59:20.931: Type : CAPWAP_MSGELE_RESULT_CODE, Length 4
*Dec 14 15:59:20.931: Result Code : CAPWAP_SUCCESS
*Dec 14 15:59:21.139: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:21.139: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:21.139: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:21.139: Msg Type : CAPWAP_CONFIGURATION_UPDATE_REQUEST
*Dec 14 15:59:21.139: Msg Length : 111
*Dec 14 15:59:21.139: Msg SeqNum : 39
*Dec 14 15:59:21.139: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 107
*Dec 14 15:59:21.139: Vendor Identifier : 0x00409600
*Dec 14 15:59:21.139: IE Length : 101
*Dec 14 15:59:21.139: Decode routine not available, Printing Hex Dump
*Dec 14 15:59:21.143:
01 0A FA 20 08 01 F4 00 07 0A FA 20 08 0C 00 01
00 00 00 00 00 00 00 00 00 00 00 00 00 24 28 2C
30 34 38 3C 40 95 99 9D A1 01 01 01 01 01 01 01
01 01 01 01 01
*Dec 14 15:59:21.143: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:21.143: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:21.143: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:21.143: Msg Type : CAPWAP_CONFIGURATION_UPDATE_RESPONSE
*Dec 14 15:59:21.143: Msg Length : 8
*Dec 14 15:59:21.143: Msg SeqNum : 39
*Dec 14 15:59:21.143: Type : CAPWAP_MSGELE_RESULT_CODE, Length 4
*Dec 14 15:59:21.143: Result Code : CAPWAP_SUCCESS
*Dec 14 15:59:25.547: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:25.547: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:25.547: Msg Type : CAPWAP_WTP_EVENT_REQUEST
*Dec 14 15:59:25.547: Msg Length : 14
*Dec 14 15:59:25.547: Msg SeqNum : 45
*Dec 14 15:59:25.547: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*Dec 14 15:59:25.547: Vendor Identifier : 0x00409600
IE : RRM_LOAD_DATA_PAYLOAD
*Dec 14 15:59:25.547: IE Length : 4
*Dec 14 15:59:25.547: slot 0 rxLoad 0 txLoad 0 ccaLoad 33
*Dec 14 15:59:25.547: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:25.555: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:25.555: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:25.555: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:25.555: Msg Type : CAPWAP_WTP_EVENT_RESPONSE
*Dec 14 15:59:25.555: Msg Length : 0
*Dec 14 15:59:25.555: Msg SeqNum : 45
*Dec 14 15:59:25.555: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:25.795: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:25.795: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:25.795: Msg Type : CAPWAP_WTP_EVENT_REQUEST
*Dec 14 15:59:25.795: Msg Length : 14
*Dec 14 15:59:25.795: Msg SeqNum : 46
*Dec 14 15:59:25.795: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*Dec 14 15:59:25.795: Vendor Identifier : 0x00409600
*Dec 14 15:59:25.795: IE Length : 4
*Dec 14 15:59:25.795: slot 1 rxLoad 0 txLoad 0 ccaLoad 0
*Dec 14 15:59:25.795: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:25.803: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:25.803: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:25.803: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:25.803: Msg Type : CAPWAP_WTP_EVENT_RESPONSE
*Dec 14 15:59:25.803: Msg Length : 0
*Dec 14 15:59:25.803: Msg SeqNum : 46
*Dec 14 15:59:25.803: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:30.375: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:30.375: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:30.375: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:30.375: Msg Type : CAPWAP_CONFIGURATION_UPDATE_REQUEST
*Dec 14 15:59:30.375: Msg Length : 17
*Dec 14 15:59:30.375: Msg SeqNum : 40
*Dec 14 15:59:30.375: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 13
*Dec 14 15:59:30.375: Vendor Identifier : 0x00409600
SlotId : 0
Mobile Mac Addr : BC:52:B7:E3:17:CB
*Dec 14 15:59:30.375: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:30.375: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 15:59:30.375: Msg Type : CAPWAP_CONFIGURATION_UPDATE_RESPONSE
*Dec 14 15:59:30.379: Msg Length : 8
*Dec 14 15:59:30.379: Msg SeqNum : 40
*Dec 14 15:59:30.379: Type : CAPWAP_MSGELE_RESULT_CODE, Length 4
*Dec 14 15:59:30.379: Result Code : CAPWAP_SUCCESS
*Dec 14 15:59:30.379: <<<< End of CAPWAP Packet >>>>
*Dec 14 15:59:30.387: <<<< Start of CAPWAP Packet >>>>
*Dec 14 15:59:30.387: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 15:59:30.387: HLEN 2, Radio ID 0, WBID 1
*Dec 14 15:59:30.387: Msg Type : CAPWAP_WTP_EVENT_RESPONSE
*Dec 14 15:59:30.387: Msg Length : 0
*Dec 14 15:59:30.387: Msg SeqNum : 47
*Dec 14 15:59:30.387: <<<< End of CAPWAP Packet >>>>
*Dec 14 16:00:00.387: <<<< Start of CAPWAP Packet >>>>
*Dec 14 16:00:00.387: CAPWAP Control mesg Sent to 10.250.32.8, Port 5246
*Dec 14 16:00:00.387: Msg Type : CAPWAP_ECHO_REQUEST
*Dec 14 16:00:00.387: Msg Length : 0
*Dec 14 16:00:00.387: Msg SeqNum : 48
*Dec 14 16:00:00.387: <<<< End of CAPWAP Packet >>>>
*Dec 14 16:00:00.395: <<<< Start of CAPWAP Packet >>>>
*Dec 14 16:00:00.395: CAPWAP Control mesg Recd from 10.250.32.8, Port 5246
*Dec 14 16:00:00.395: HLEN 2, Radio ID 0, WBID 1
*Dec 14 16:00:00.395: Msg Type : CAPWAP_ECHO_RESPONSE
*Dec 14 16:00:00.395: Msg Length : 15
*Dec 14 16:00:00.395: Msg SeqNum : 48
*Dec 14 16:00:00.395: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 11
*Dec 14 16:00:00.395: Vendor Identifier : 0x00409600
IE : UNKNOWN IE 151
*Dec 14 16:00:00.395: IE Length : 5
*Dec 14 16:00:00.395: Decode routine not available, Printing Hex Dump
52 AC 80 81 00
*Dec 14 16:00:00.395: <<<< End of CAPWAP Packet >>>>
Solved! Go to Solution.
03-06-2014 05:50 AM
Alright, so this ended up being a combination of a couple different things. Firstly I needed to change a default gateway for the WLC interface at our CoLo because the WLC couldn't route traffic to all locations. The other and most important find was the issue with the APs not staying joined to the WLC. This was because of our existing logical network setup and the crux of the problem was our Business Wireless and Virtual IP Interface was sharing the same subnet as our wired network. I have since segmented the wireless from the wired subnets and everything seems to be communiating properly now.
06-28-2015 08:44 PM
We are trying to get a 2602e ap work as indoor mesh unit but AP is not joining WLC - the debug does not indicate a problem - shown below
any idea why?
(Cisco Controller) >show ap join stats summary all
Base Mac AP EthernetMac AP Name IP Address Status
c8:00:84:61:c5:d0 N A AP84b8.0281.ac9a 10.38.53.9 Not Joined
WLC 5508 running code 7.4.121.0
AP version - from CDP
(AP3G2-K9W8-M), Version 15.2(2)JB3
Device ID: AP84b8.0281.ac9a
Entry address(es):
IP address: 10.38.53.5
Platform: cisco AIR-CAP2602E-Z-K9 , Capabilities: Router Trans-Bridge
Interface: FastEthernet0/6, Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 165 sec
Version :
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 04:30 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 22519, Power management id: 1
Power request levels are:15400 0 0 0 0
Management address(es):
Debug info
*spamApTask3: Jun 29 12:31:43.071: <<<< Start of CAPWAP Packet >>>>
*spamApTask3: Jun 29 12:31:43.071: CAPWAP Control mesg Recd from 10.38.53.9, Port 6858
*spamApTask3: Jun 29 12:31:43.071: HLEN 4, Radio ID 0, WBID 1
*spamApTask3: Jun 29 12:31:43.071: Msg Type : CAPWAP_PRIMARY_DISCOVERY_REQUEST
*spamApTask3: Jun 29 12:31:43.071: Msg Length : 99
*spamApTask3: Jun 29 12:31:43.071: Msg SeqNum : 0
*spamApTask3: Jun 29 12:31:43.071: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask3: Jun 29 12:31:43.071: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask3: Jun 29 12:31:43.071: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask3: Jun 29 12:31:43.071: Maximum Radios Supported : 2
*spamApTask3: Jun 29 12:31:43.071: Radios in Use : 2
*spamApTask3: Jun 29 12:31:43.071: Encryption Capabilities : 0x00 0x01
*spamApTask3: Jun 29 12:31:43.071: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask3: Jun 29 12:31:43.071: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask3: Jun 29 12:31:43.071: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask3: Jun 29 12:31:43.071: WTP Mac Type : SPLIT_MAC
*spamApTask3: Jun 29 12:31:43.071: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamApTask3: Jun 29 12:31:43.071: Vendor Identifier : 0x00409600
IE : UNKNOWN IE 207
*spamApTask3: Jun 29 12:31:43.071: IE Length : 4
*spamApTask3: Jun 29 12:31:43.071: Decode routine not available, Printing Hex Dump
*spamApTask3: Jun 29 12:31:43.072: 00000000: 03 00 00 01 ....
*spamApTask3: Jun 29 12:31:43.072: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 22
*spamApTask3: Jun 29 12:31:43.072: Vendor Identifier : 0x00409600
IE : RAD_NAME_PAYLOAD
*spamApTask3: Jun 29 12:31:43.072: IE Length : 16
*spamApTask3: Jun 29 12:31:43.072: Rad Name :
*spamApTask3: Jun 29 12:31:43.072: AP84b8.0281.ac9a
*spamApTask3: Jun 29 12:31:43.072: <<<< End of CAPWAP Packet >>>>
