04-06-2017 02:20 PM - edited 07-05-2021 06:49 AM
WLC controller based configuration allows for the ability to turn off the status LED on the WAPs. After converting the setup to Mobility Express I cannot for the life of me see any way to do it in the GUI (browser) or the CLI. Any undocumented commands I can run to turn off the LED like I can when the APs are managed by a WLC?
Solved! Go to Solution.
04-07-2017 12:32 AM
Can you try this command on CLI:
config ap led-state { enable | disable} { cisco_ap | all}
Dont forget to rate helpful posts
04-07-2017 12:32 AM
04-07-2017 08:08 AM
Thanks Sandeep, that worked. The command needs to be issued on the mobility express controller.
