Community Helping Community
151
Beginner
turning off diversity on AP1602
HI All,
We have new access point lightway AIR-CAP1602-EK9 and Cisco Controller WLC 5508  with version 7.4.110.0.
I would like to know how can we trun off diversity which I belive is turnd on by default..
Thank you
2 REPLIES 2
Rising star
config 802.11 antenna
config 802.11 antenna diversity
To configure the diversity option for 802.11 antennas, use the config 802.11 antenna diversity command.
config 802.11{a | b} antenna diversity {enable | sideA | sideB} cisco_ap
Syntax Description
config
Configuration settings.
802.11
802.11 network settings.
a | b
Specifies 802.11a or 802.11b/g network.
antenna diversity
Configure antenna diversity settings.
enable
Between the two internal antennas.
sideA
Between the internal antennas and an external antenna connected to the Cisco lightweight access point left port.
sideB
Between the internal antennas and an external antenna connected to the Cisco lightweight access point right port.
cisco_ap
Cisco lightweight access point name.
Highlighted
Beginner
I am guessing that what you
I am guessing that what you want to do is use an antenna that does not have 3 leads on it.  To disable an antenna port on the access point you will need to do the following:
  • Go to the wireless tab
  • Select 802.11a/n/ac in the Access Points section on the left
  • Hover over the blue arrow on the right for the AP you want to disable the antenna port on and select configure
  • In the antenna properties section un-check the antenna ports you want disabled
  • Repeat this process in the 802.11b/g/n Access Points section to disable the port for both radios
I hope this helps.
John
Content for Community-Ad
August's Community Spotlight Awards
