Two AP with the same name join WLC
wfqk
Level 5
Level 5
Hi there are two APs, which have the same name. If the first one already join the WLC, do you think the second one still can join the WLC? Thank you
3 Accepted Solutions
johnd2310
Level 8
Level 8
In some case i  have seen two access points with the same name join the controller but the second access point to join will show the mac address as the name i.e. the AP name field will be a mac address.
John
**Please rate posts you find helpful**
@johnd2310 I Agree :)
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Jonas Kalldert
Hi showipinterface,
I got interested and did a lab to test this.
The AP will join but it will revert the AP name to the default name: APaaaa.bbbb.cccc
regards,
Jonas
**Don't forget to rate helpful posts**
5 Replies 5
Hi @wfqk
Corrected aftr testing: it will join and change the name to default as APmacaddress
Also if you are trying to change the hostname of AP joined to a controller with same hostname of another AP it will give you a error "Error: Cannot set a duplicate AP Name"
johnd2310
Level 8
Level 8
John
Jonas Kalldert
Hi showipinterface,
regards,
Jonas
Thank you all!
