400
Contributor
Two AP with the same name join WLC
Hi there are two APs, which have the same name. If the first one already join the WLC, do you think the second one still can join the WLC? Thank you
3 ACCEPTED SOLUTIONS
Collaborator
Re: Two AP with the same name join WLC
In some case i  have seen two access points with the same name join the controller but the second access point to join will show the mac address as the name i.e. the AP name field will be a mac address.
John
**Please rate posts you find helpful**
@johnd2310 I Agree :)
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Beginner
Hi showipinterface,
I got interested and did a lab to test this.
The AP will join but it will revert the AP name to the default name: APaaaa.bbbb.cccc
regards,
Jonas
**Don't forget to rate helpful posts**
5 REPLIES 5
Hi @showipinterface
Corrected aftr testing: it will join and change the name to default as APmacaddress
Also if you are trying to change the hostname of AP joined to a controller with same hostname of another AP it will give you a error "Error: Cannot set a duplicate AP Name"
Collaborator
John
Beginner
Hi showipinterface,
regards,
Jonas
Highlighted
Contributor
Thank you all!
Content for Community-Ad
August's Community Spotlight Awards
