02-14-2020 05:43 AM - edited 07-05-2021 11:43 AM
Hi All,
Recently I've encountered on a problem where I have two different SSIDs configured on the Wireless LAN Controller. However both are using the same VLAN interface thus they use the same subnet. There is configured like this, because one SSID will soon replace the other one. One WLAN has a different method of authentication, but this method is configured on the RADIUS server, thus in fact they are the same WLANs. The same in terms of configuration on WLC. The only difference on WLC is the SSID and the one network doesn't broadcast SSID. Both are added to the same AP Groups, thus are broadcasted by the same Access Points, but what is strange, PCs using these WLANs detects that one WLAN has better signal strength while other has worse signal. It was not measured yet by any application. This will be done soon, however Windows shows more signal bars for one WLAN but less for others.
Can someone give a hint, why such thing is happening? What can cause that?
02-14-2020 05:51 AM
Doen´t make sense they show different signal level. Not saying they are not. As you already states, it is importante to mesure this with different tools rather than windows.
-If I helped you somehow, please, rate it as useful.-
02-14-2020 06:13 AM
02-14-2020 06:27 AM
That´s right. Make no sense. Considering windows is not reliable as a RF tool, I´d prefer mesure it with some RF tools to make sure.
02-14-2020 03:31 PM
I think this is the "application" (or not) attempting to measure the RSSI. Windows "native" WLAN application is not a suitable tool to measure RSSI. It's main function is to tell you if there is wireless or not.
There are several free WiFi "analyzer" tools in the Windows Store that can be used.
Also, make sure the reading is consistently taken from the same AP. If there are more than one AP broadcasting the SSIDs then there will be issues.
