two ssid some vlan in wireless controller
andrespipe1690
hello community,
Hello community,
We currently have a wireless controller 2500 and 2600 access points, the question is if the 2500 controller can have two SSID for the same VLAN
thank you
7 Replies 7
Leo Laohoo
Yes.
hello leo, Thanks for the reply,
There is a manual which process is described, because when running and indicates that the VLAN ID is being used by another SSID
Thank
When creating an SSID, one can choose the Interface where the SSID will "pipe" out to.
ok Leo,
I will try again, and I'm commenting on the result.
thanks
There are two different things:
1) You can have multiple SSIDs (WLAN) associated with the same VLAN interface.
2) But, you can't have multiple interfaces with the same VLAN ID.
Hope that helps!
Cheers,
VB
Hi VB,
yes is correct,
thank
