Unable to ping from access Point 1832I but able to ping from WLC 3504
yasib ahmed
We are using 3504 controller with 1832I AP. we are created IPSec VPN in our router to connect remote Site.We are able to ping from WLC to remote site VPN but unable to ping using wifi access point. I have checked my firewall and there is nothing any block, all are permitted and allow. I don't know where is the problem.
I have configure WLC management with VLAN 68 and connect WLC to Switch with Trunk port. and AP are connect with access VLAN 68. From WLC can ping remote site easily but from AP can not ping.It will reach only to gateway.
Need your expert suggestion to solve my problem. Here i attached the screen shoot of my ping status.
omz
If the SSID is configured correctly, may be worth disabling Windows firewall for a quick test.
Yes my firewall is also disable. Still the same problem
manjit_raulo
Have you checked the route for your ap management vlan on the router ?
Yes route is enable. Its just a simple default route.
I have Network 10.55.68.0/22 and WLC Management Vlan 68 and IP 10.55.68.2.
DHCP is broadcast from WLC and DHCP Pool is 10.55.68.100 to 10.55.71.250.
