12-03-2018 08:53 AM - edited 07-05-2021 09:31 AM
Hi Guys, I need assistance finding why I'm not able to access the WLC GUI. I am not able to ping the management interface IP address neither. Everything was working fine until I added EACL to my switch. So I revert the configuration to previous one but the issue persist. Here is the current configuration for my switch and WLC IP address information. Thank You.
12-03-2018 09:37 AM
12-03-2018 12:00 PM
What interface connect to WLC ? Where did you apply ACL & remove later on ?
Rasika
12-03-2018 12:58 PM
Hi Rasika,
Thanks for your answer. WLC is using interface Gi1/1. And I applied ACLS on the switch but I deleted them since my MAP's were not able to join the WLC, but that is a different issue. Right now is just that basic configuration no ACL on switch. Thank You
12-03-2018 01:10 PM
From WLC, can you ping vlan 20 gateway IP address ?
Also I noticed you only allowed vlan 20 traffic on G1/1 interface, if you are using other vlans for wireless users, you have to allow those vlan across that trunk link.
Rasika
12-03-2018 01:37 PM
I haven't assigned any IP to VLAN 20. but all devices assigned to VLAN 20 are replying to the eco command, ping.
12-03-2018 02:31 PM
Pls provide output "show interface detailed management" from your WLC
Rasika
12-04-2018 05:12 AM
12-04-2018 09:06 AM
Tks for the output.
Can you ping 10.232.161.75 from your WLC ?
Rasika
12-04-2018 12:19 PM
Not able to ping gateway IP, I can pin its own WLC IP address. I would think it is an issue with the Switch but all interfaces are indicating connected when I run the sh inter status command.
12-04-2018 12:24 PM
Verify using "show cdp nei" from WLC.
If it is showing g1/1, for the time being remove "switchport trunk allowed vlan 20" & test ping again. If no success, it is a basic connectivity issue. On which switch/L3 devive you defined interface vlan 20 ? check layer 2 vlan exist across switch network upto its gateway
Rasika
*** Pls rate all useful responses ***
12-04-2018 12:39 PM
12-04-2018 06:39 PM
You can console into your WLC.
Rasika
