07-25-2012 06:59 AM - edited 07-03-2021 10:27 PM
I am using Cisco 3560 POE -WS-C3560CG-8PC-S- switch for my AP's. The current IOS i got on this switch don't allow me to use web console. when i am click on webconsole i am getting attached. Could any one please tell me what is the best way of removing and installing new IOS.
Solved! Go to Solution.
07-25-2012 07:14 AM
Well... I don't think many use the GUI for configuration of the switch. Most of the configuration documentation is all command line (cli). Your best bet is to learn the command line.
07-25-2012 07:22 AM
I don't think any IOS code will differ from what you see now. That is normal, well from what I have seen. It's very limited in function as you can see.
07-25-2012 07:14 AM
07-25-2012 07:19 AM
Hi Scott, I do know how to use the CLI but i though might be good idea to have web console. I know where you coming form its alot of work isint. I probably leave it as i can always access it via console.
07-25-2012 07:22 AM
07-25-2012 07:29 AM
oh ok thanks save me from spending couple of hours on this thanks
07-25-2012 07:31 AM
No problem... Good luck there!
