794
Highlighted
Upgrade AIR-LAP1141N IOS Version
How can i upgrade the AIR-LAP IOS Version from 12.4(21a)JA to 15.2(2)JB to try joinning to my vWLC Release 7.4.100
This AIR-LAP has never been joinned to any controller, and i have access to CLI Console.
I try typing archive and upgrade commands but are marked as '%Unrecognized Commands'
after a question mark "?" i see "upgrade" command but is still marked as '%Unrecognized Commands'
i have the TFTP server with my ios image.
Can somene help me about?, What i have to do to upgrade this AP.?
Thanks in advance for your help.
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: Upgrade AIR-LAP1141N IOS Version
issue the following:
debug lwapp console cli
Make sure you type it all in as the '?' Will not show the command
Now you will be able to do the archive command. The other way is to do the following:
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
5 REPLIES 5
Hall of Fame Master
-Scott
Thanks Scott, but i have another question, Can i upgrade the LWAPP IOS Version A (For Example) to LWAPP IOS Version B directly, or I have to Convert LWAPP to AP and then Convert again the AP to LWAPP with the newest version.
Thanks for your information again.
Hall of Fame Master
You can upgrade to any image... as long as the image is for the ap model you have. The links I posted is how to get an image on the ap.
-Scott
Re:Upgrade AIR-LAP1141N IOS Version
Thanks Scott, i did this procedure and i succesfully upgrade these AIR-LAPs
Thanks for your help.
Sent from Cisco Technical Support Android App
Hall of Fame Master
Re: Re:Upgrade AIR-LAP1141N IOS Version
Glad you got it working.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
