02-24-2014 01:42 PM - edited 07-05-2021 12:16 AM
Is a FUS upgrade required to uprade from 7.0.235.5 to 7.6.100.0?
Solved! Go to Solution.
02-24-2014 01:45 PM
Hi Rob,
It is strongly recommended.
Go to FUS 1.9.0.0 as that is the latest
Rasika
02-24-2014 01:54 PM
02-24-2014 02:22 PM
There have been stuff mentioned that when upgrading, that you apply FUS 1.8.0.0 when at release v7.4. Now I think most people have applied the FUS 1.7.0.0 and 1.8.0.0, but upgrading direct from v7.0.x to v7.6 and them just applying the FUS 1.9.0.0 might be interesting to say the least. Let us know if you go direct and it works fine.
02-24-2014 01:45 PM
Hi Rob,
Rasika
02-24-2014 01:54 PM
Yes.
02-24-2014 02:22 PM
02-26-2014 11:51 AM
Please go through the document for the details of WLC 5508 software -
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
