Upgrade WLC in HA AP SSO mode
Hi all,
I have a question regarding IOS upgrade on WLCs in HA AP SSO mode.
What would be the best solution to update the IOS on the whole cluster without a downtime?
Will each WLC be updated device by device or both at the same time? So I need a downtime during the update...
Or do I have to remove the AP SSO mode on both WLCs and update both by myself?
Thanks for your answers!
BR, Stefan
Sandeep Choudhary
HI Stefan,
It would be good If you will take a downtime for any worst case and the upload new IOS to WLCs.
You manuall have to upload IOS on bOth WLC.
here the link which is expamples for HA config
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
https://supportforums.cisco.com/docs/DOC-26827
http://www.cisco.com/en/US/docs/wireless/technology/hi_avail/N1_HA_Overview.html
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps10315/qa_c67-714540.html
Dont forget to rate helpful posts
5 Replies 5
Sandeep Choudhary
HI Stefan,
Thank you for your answer!
Maybe I should read through the artices with open eyes --> "Upgrade Procedure in HA Setup"
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml#upgradesteps
THANKS!
Sandeep Choudhary
Also check this doc:
Which controller models also provide the -HA SKU, and which support the stateful switchover (SSO) functionality:
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps10315/qa_c67-714540_ps2706_Products_Q_and_A_Item.html
  • When AP SSO is enabled, there is no SNMP/GUI access on the service port for both the WLCs in the HA setup.
Leo Laohoo
Not possible.  Here's the logic:
Let's say you are able to successfully push the firmware to the two units.  If you reload only one of them, the one being reloaded will NOT be able to join the HA SSO pairing because of firmware incompatibility.  \
I just finished an upgrade of three pairs of WiSM-2 HA AP SSO.  What I've done is push the firmware across, force the APs to pre-download the firmware and then reboot the pair of WiSMs.  The reboot is scheduled for 4 am.
Another alteration is this:
Let's say you have TWO pairs of WiSM-2 and both pairs are in AP SSO.
So you push the firmware to the two pairs.  Next, you force the AP in one pair to go to the second pair.  Reboot the first pair.  For APs in the second pair, trigger the AP pre-download.  Once the first pair of WLC come back online, move all the APs in the second pair to go to the first WLC.  Once the APs have rebooted and joined the first WLC, reboot the second pair of WLC.
Sounds logically
The only problem is that I only have one pair of Cisco WLC 5508, so I am not able to move the access points to another WLC pair...
However I will try to communicate this solution to the operation team.
THANKS for your answer!!!
