10-30-2015 06:32 AM - edited 07-05-2021 04:09 AM
Hi all,
I want to upgrade a 5508 WLC which is currently running 7.0.116.0 to 7.4.130.0. The FUS on the controller is 6.0.182.0 and in the release notes it is recommended to use 1.7.0.0-FUS (which is no longer available).
Can I bypass the FUS upgrade (which i'd rather not do) or just go straigh to 1.9?
Thanks.
Solved! Go to Solution.
10-30-2015 06:44 AM
Yes you can go straight to the 1.9 FUS image.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.html
HTH,
Steve
10-30-2015 06:44 AM
HTH,
Steve
10-30-2015 06:47 AM
Thanks Steve.
