11-09-2019 04:59 AM - edited 07-05-2021 11:17 AM
Could someone please provide me with the procedure on how to upload the upgrade file to the CMX virtual appliance drive?
Solved! Go to Solution.
11-10-2019 01:58 AM
Thanks for the information, but Cisco advises you to upgrade the versions 10.6.x from the cli and not with the gui.
I have figured out how to upload the file. The reason I was unable to do is. I was using the protocol SFTP and not SCP. As soon as I switched to the SCP protocol. I was able to upload the file without any issue.
11-09-2019 07:58 AM
11-09-2019 10:52 AM
if you already got CMX installed, then you can go to upgrade page by simply following URL. You should see a page like below
Rasika
*** Pls rate all useful responses ***
11-10-2019 01:58 AM
11-10-2019 08:32 AM
