10-07-2012
07:04 PM
- last edited on
07-03-2021
10:46 PM
by
cc_security_lab
On our conference floor, AP 1242AG already exist but I am going to add AP 3602i to increase wireless coverage. . Any issue or concern with this type of setting?
10-07-2012 07:34 PM
You can, but you shouldn't enable CleanAir in a mixed environment.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
10-07-2012 07:36 PM
You understand that the 3600's require v7.2 or newer.
Scott
10-07-2012 07:41 PM
All 3602 are on 7.2.110 same as WLC.
10-07-2012 07:44 PM
You can add the 3600's, just don't enable CleanAir in a mixed environment.
10-07-2012 08:38 PM
I wouldn't think simply having CleanAir enabled would be a problem as it can still be used for reporting of AQ and other useful information about non-WiFi interferers, but you may not want to enable Event Driven RRM.
10-08-2012 01:18 AM
Yea, its the EDRRM that you need to be careful with in a mixed environment.
__________________________________________________________________________________________
10-08-2012 08:41 AM
I believe EDRRM setting is on the WLC 5508. On the same controller, other floors are only using CAP 3602i. Is it a good idea to disable EDRRM?
10-08-2012 08:44 AM
If you are in a mixed AP environment and not running 7.3, you should not enable EDRRM. With 7.3 the Persistent Device Interferers list is shared, prior to that it is not.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
10-08-2012 10:39 AM
Disable EDRRM on the controller because of AP 1242AG?
10-08-2012 10:40 AM
correct
HTH,
Steve
10-08-2012 11:37 AM
Stephen, My option is put all 1242 on one controller with EDRRM disable and 3602 on another one. It is ok to have 1242 and 3602 physically next to each other, right?
10-08-2012 11:40 AM
You could do that, but I still wouldn't enable EDRRM.
RRM is going to run across the RFgroup that will be configured between the two WLC. So could still have issues with only some AP using EDRRM, and the others not.
Per best practices, EDRRM shouldn't be enabled in a mixed deployment, unless you are on 7.3.
HTH,
Steve
10-08-2012 12:11 PM
If I disable EDRRM on WLCs, does it cause problem for users are connecting to 3602i?
10-08-2012 12:17 PM
No it doesn't. You'll be fine.
