05-18-2015 06:20 AM - edited 07-05-2021 03:15 AM
Hi guys,
I have a Cisco Linksys E1200 router. I'm trying to use this router as an access point. I've followed p.36 of this manual: http://downloads.linksys.com/downloads/userguide/E_Series_UG_E900Rev_3425-01486_Web.pdf which, in point 4, says to find "bridge mode" in Cisco connect. I can't find bridge mode in the settings.
Can somebody please give me a screenshot, or direct me to exactly where bridge mode is?
05-19-2015 07:01 AM
Select the Bridge Mode using the following steps.
05-19-2015 11:39 AM
Please refer :
http://jgiam.com/2012/07/06/setting-up-a-repeater-bridge-with-dd-wrt-and-d-link-dir-600
05-20-2015 04:56 AM
follow the discussions
https://community.linksys.com/t5/Wireless-Routers/Configuring-e1200-as-wireless-bridge/td-p/532530
05-21-2015 12:33 PM
In the Internet Connection Type drop-down list, click the type of
Internet connection provided by your ISP and select the option as Bridge mode.
Below is the screenshot and let me know If you need any other assistance.
06-04-2016 10:17 AM
The Firmware of your Linksys E1200 router is too old. You can get a newer at http://www.linksys.com/us/support-article?articleNum=148523 and you can read (current firmware for version 1 is 1.0.04) but bridge support has been added on 1.0.02. Just dowload and go to Firmware update and you will the bridge facility.
Firmware 1.0.02 (build 5) - Added bridge mode support
