Variable Response times
In the operation of the WLC, I see that the response time is variable between 2-4ms and 800-1000 ms  at the highest response time, falls to the ideal response time, again and again.
The WLC has the basic configuration five SSID and I am the only user on the WLC.
I Want to know any solution to this fail.
provide more info about your WLC. Pls provide output of "show sysinfo"
Rasika
Thanks, the sysinfo...
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.115.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... WLC_01_ID205
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.104.191.139
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 6 days 14 hrs 25 mins 24 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... CO  - Colombia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +32 C
External Temperature............................. +37 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 8
Number of Active Clients......................... 16
Burned-in MAC Address............................ 68:9C:E2:BF:24:40
Maximum number of APs supported.................. 75
System Nas-Id.................................... Cisco_bf:24:44
WLC MIC Certificate Types........................ SHA1/SHA2
