ā04-22-2016 03:07 AM - edited ā07-05-2021 04:55 AM
Hi there ,
I just set up a virtual WLC and configured Aps with 3 SSID.
I configured APs in flexconnect mode, since with local mode , i couldn't see my SSIDs broadcast.
Now most of users , aprox 90% are connected, but 10% cannot see the SSIDs . It's not a coverage issue, because we tested many devices in the same room of the affected users and we can see this SSIDs.
Any idea
Thanks in advance
Solved! Go to Solution.
ā04-22-2016 03:35 AM
Please check if any AP Groups except default group created on WLC!!!
Don't forget to rate helpful posts
ā04-22-2016 04:16 AM
Please also check the data rates allowed in both band!!!
Reagrds
ā04-22-2016 03:38 AM
Hello Sandeep,
Thank you for your help.
I have not configured any new AP Group. I have only the default.
Reagrds
ā04-22-2016 04:20 AM
Thanks Sandeep,
You saved me.
It was a data rate issue.
