150
Highlighted
Beginner
VLAN and vWLC
Hi all,
My vWLC is in VLAN 100 and all APs are in VLAN 101. I need to know, if joining process of all APs to vWLC will accur normally or I must configure other things related to VLAN Tagging ?
Best regards,
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Community Legend
No, i haven't do anything
No, i haven't do anything accurding to DHCP Service.
If the APs and WLC management interface are in the same subnet then the APs will be able to join the controller.
If the APs are in a different subnet then some kind of mechanism is required for the APs to find their controllers.  Manually, each APs can be configured to go to a specific WLC.  The most efficient method is to use DHCP Option 43.
4 REPLIES 4
Is DHCP Option 43 configured correctly?
Beginner
Thank you Mr. Leo for
Thank you Mr. Leo for replying,
Beginner
Thank you Mr. Leo
Thank you Mr. Leo
So, I need to configure DHCP Option 43.
Content for Community-Ad
August's Community Spotlight Awards
