282
Highlighted
Beginner
vWLC 8.0.120 ver
Hi all,
it is recommanded to use AIR-CTVM-K9-8-0-121-0.ova ? i mean it is stable version or I should use an older version ?
thank's in advance
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Advisor
Depending on features needed you can move forward with this version. Take a look at release notes to see what are the features and resolved/pending caveats.
However, if you want to have the best stable version, follow Cisco recommendation that is to go with AireOS version 7.4.140
See screenshot attached.
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
7 REPLIES 7
VIP Advisor
Francesco
Beginner
Thnk you for all,
Thank you for all,
But I have installed the 8.0.121 ver and activate it with my PAK, if I download the 7.4 ver, can I use the same license or I need to contact cisco license team to send me a new license ?
thank you for patience
VIP Advisor
Licenses isn't my expertise
Licenses isn't my expertise but there are based on serial then if you reinstall your serial might change. Just send a mail to licensing and you will get quickly a new license for the new wlc.
Again before downgrading, just compare features to check if you need maybe a specific feature that's only in version 8
Francesco
Beginner
thank you a lot
thank you a lot
Best regards,
VIP Advisor
You're very welcome
You're very welcome
Francesco
VIP Mentor
I don't experience with vWLC.
I don't have experience with vWLC..... but....
Normally if you downgrade or upgrade cisco WLC software then you don't need to have a new license. WLC will keep the same old .lic file.
Dont forget to rate helpful posts
VIP Mentor
I agree with Supportlan.
As per Cisco Recommendation/documentation 7.4.140.0(MD) is the most stable version.
If you need the latest features then of-course you can go with 8.0 or 8.2 series.
Content for Community-Ad
August's Community Spotlight Awards
