05-13-2019 06:07 AM - edited 07-05-2021 10:23 AM
Having an issue with clients connecting to various WLANs getting DHCP leases from a scope configured for another VLAN. It was previously working for a couple days, but seemed to all of a sudden change to incorrect DHCP leases. Ex. a client connecting to WLAN99, configured for interface vlan99 on the vWLC, will get a dhcp lease of 10.2.0.X. The same event occurs when connecting to WLAN11, configured for interface vlan11 on the vWLC, getting 10.2.0.X. Intermittently, the WLAN99 wlan will get assigned 10.99.0.X.
This setup was previously working correctly, but seemingly started occurring randomly yesterday afternoon.
I have tried removing IP helper config off the routers sub-if for each vlan, doing so prevents any DHCP leases.
Objective:
Segregate traffic based on vlan. Router has ACL's to filter traffic based on vlan, (vlan 2,10,11 have access to other vlans, 99 is traffic leaving the network)
Setup:
VLANS- 10-10.0.0.X - internal wired
11-10.0.1.X - internal wireless
2-10.2.0.x - management
99-10.99.0.x - guest internet
vWLC- Port 1-VLAN 2
Port 2-Trunk
Switch(2960x)-All vlans configured on switch. vWLC connected to vSwitch with Trunk and VLAN 2, two vnics. Port channel to vSwitch configured as trunk, all vlans permitted.
AP x3 (2702i)-connected to switch on gig2/0/1-3, switchport trunk, native vlan 2.
Router x2 - gig0/0/2.2 , 0/0/2.10 , 0/0/2.11 and 0/0/2.99 - all have "ip helper address (dhcpserver1 on vlan10), ip helper address (dhcpserver2 on vlan10)". Router is configured for HSRP (if that matters.)
DHCP server (10.0.0.50, 10.0.0.51)- Scopes configured for 10.0.0.X, 10.0.1.X, 10.2.0.X and 10.99.0.X.
Not sure where the issue in the config is, hopefully its a simple oversight on config. Im new to the wlc setup.
Solved! Go to Solution.
05-13-2019 01:52 PM
Not sure, what you're referring to.
You need to configure the WLAN-VLAN mappings on the FlexConnect Group. Not the interface setting on the WLANs.
05-13-2019 06:56 AM
05-13-2019 10:54 AM - edited 05-13-2019 10:56 AM
Vwlc support only FLexconnect local switching..
So globally mapping interface on wlan will not take effect, you should check in wlan-vlan on flex groups or flex Tab on individual Ap's config.
Hope this helps..
Vengat
05-13-2019 11:09 AM
05-13-2019 01:52 PM
05-14-2019 05:48 AM
Yeah that was it, was missing the WLAN-VLAN mappings in flex connect groups.
12-06-2021 09:36 PM
For me it did not work WLAN-VLAN, vWLC version is 8.5.161 and CAP2600
