Watchdog for Cisco Aironet 1815i Access Point
Ivane Sajaia
Hello
one of the access points need hardware restart every other day to keep it working, like it works fine for 1 or 2 days and it randomly starts, for start i tried to downgrade firmware to stable version i had 8.8.100.0 now i have it on 8.5.151.0, i have some experience with ubiquiti and mikrotik devices, and im looking to find out if Cisco Aironet 1815i Access Point has watchdog feature, or IP SLA or something that will do similiar work
thanks in advance
patoberli
Is it only this one AP? Do you have others of the same model without the issue?
If both is yes, I suggest to RMA it.
We have 4 same model AP on site and only one AP has this issue, others are fine.
is there any other way?
thanks
You could use a PoE adapter, which is attached to a time switch, but this is a really bad solution in my opinion.
