07-06-2016 12:28 AM - edited 07-05-2021 05:22 AM
I have set up a web authentication with the internal Portal, and it works fine.
Layer 2 security is none, Later 3 securiy is web Policy with "Authentication".
When I changed the Web Authentication Type to "External", it didn't work.
I have enabled the debug " web-auth redirect enable mac xx:xx:xx:xx:xx:xx", from the logs it shown "can not get the index of protal server"
And from the client's browser it shown the URL:
"http://10.75.156.50?switch_url=http://1.1.1.1/login.html&ap_mac=d8:b1:90:b2:a8:70&client_mac=7c:fa:df:88:be:87&wlan=Guest-Central&", but never shown the actual web page.
Also I have tried to disable the "WebAuth SecureWeb" and "HTTPS Redirection", after the WLC rebooting, it shown the same error.
I have tried the IPHONE and the windows 10, haven't tried the other devices yet.
Please someone tell me where am I wrong?
Error logs:
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- str1 is now http://10.75.156.50?switch_url=http://1.1.1.1/login.html&ap_mac=d8:b1:90:b2:a8:70&client_mac=7c:fa:df:88:be:87&wlan=Guest-Central&redirect=10.75.156.50/?swit
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- clen string is Content-Length: 661
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- Message to be sent is
HTTP/1.1 200 OK
Location: http://10.75.156.50?switch_url=http://1.1.1.1/login.html&ap_mac=d8:b1:90:b2:a8:70&client_mac=7c:fa:df:88:be:87&wlan=Gue
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- send data length=1146
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- Url:http://10.75.156.50
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- can not get the index of protal server
*webauthRedirect: Jul 06 15:27:29.515: 7c:fa:df:88:be:87- cleaning up after send
*webauthRedirect: Jul 06 15:27:29.515: 1520 - 7c:fa:df:88:be:87- closing socket= 83
07-06-2016 02:25 AM
Hello Jia
Please look in this configuration example once again and verify with your configuration setup .
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/71881-ext-web-auth-wlc.html
Thank you
07-06-2016 06:36 AM
Hi Prakash,
Thank you for reply,
My WLC version is 8.0, so I don't have an "add web server" button, but the other is same.
And the WLC will show nothing when I set up a preauthentication ACL.(I enabled the counter, the acl hits number grows, but shown nothing from "debug web-auth redirect enable mac xx:xx:xx:xx:xx:xx")
I'll post my config if it's necessary.
07-06-2016 08:45 PM
