06-04-2019 06:36 PM - edited 07-05-2021 10:30 AM
Hi Please see the below, which is from output of command netsh wlan show interface in PC:
My question is what decide the speed. In this case, Receive/Transmit Rate are 65 Mbps. It looks like distance and signal strength do not impact the rate. Anyone can explain it? Thank you
C:\Users\G>netsh wlan show interface
There is 1 interface on the system:
Description : 802.11n USB Wireless LAN Card #2
GUID : 60ae483-05f8-413-9f27-079c15cead9
Physical address : 00:0f:01:43:23:f7
State : connected
SSID : Fios-3BOZ
BSSID : 20:c0:47:dd:a2:f0
Network type : Infrastructure
Radio type : 802.11n
Authentication : WPA2-Personal
Cipher : CCMP
Connection mode : Auto Connect
Channel : 1
Receive rate (Mbps) : 65
Transmit rate (Mbps) : 65
Signal : 60%
Profile : Fios-3BOZ
Hosted network status : Not started
06-04-2019 10:25 PM
Its complicated.
Higher signal strengths enable the use of higher PHY (PHYsical layer data) rates, also known as MCS (Modulation and Coding Scheme). Data rates highly dependent on the capabilities of the transmitting radio, the receiving radio and the environment. Signal strength (in dB) is directly proportional to the rate at which it can transfer data.
Mode | Maximum rate | Antenna transmit / Receive arrangements |
1x1 20 MHz | 72.2 Mbps | 1 TX 1 RX |
1x1 40 Mhz | 150 Mbps | 1 TX 1 RX |
2x2 20 MHz | 144.4 Mbps | 2 TX 2 RX |
2x2 40 MHz | 300 Mbps | 2 TX 2 RX |
3x3 20 MHz | 216.7 Mbps | 3 TX 3 RX |
3x3 40 MHz | 450 Mbps | 3 TX 3 RX |
Hope this helps.
06-05-2019 06:42 AM - edited 06-05-2019 06:46 AM
Thank you so much for your reply
Based on these message you provided, it looks like 2x2 20 MHz 144.4 Mbps is double of 1x1 20 MHz. so how can we make 1x1 become 2x2? and how can we make/configure 20 MHz become 40 MHz?
Can you send me a link? thanks
06-05-2019 09:59 AM
06-07-2019 12:40 PM
Very good explanation! thank you very much.
