07-22-2019 04:58 AM - edited 07-05-2021 10:44 AM
I am setting up a wireless lab with 5 Cisco Air-Cap3502I-L-K9's and Cisco Virtual Wireless Lan Controller.
I've reset the AP (at least I'm pretty sure I have) and I seem to have issues getting the AP's to connect to the VWLC.
This message is displayed every 30 seconds or so.
Not in Bound state. *Mar 1 00:20:18.082: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP. *Mar 1 00:20:21.105: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.5.115, mask 255.255.255.0, hostname AP7081.05b0.f082 Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.5.2)
Also, here's the vWLC IP info:
Management : Port 1; Vlan ID 100; IP Address: 10.0.0.2; Type: Static; AP Mgr: yes;
Service Port: Port: N/A; Vlan ID: N/A; IP Address: 192.168.5.113; DHCP: No; AP Mgr: No
So I'm confused, im trying to get the ap to connect to the service port @ 192.168.5.113 and it doesn't seem to be able to connect. Does it need to connect to 10.0.0.2? If so, do I need to change any settings on my network? The network operates on the 192.168.5... range so does something need to change?
Also, why is it "translating cisco-capwap-controller" / what does that mean? Is it trying to look up the ip of that hostname?
I haven't done any other configuration to the AP, i just reset it, and as far as I can tell, the AP should just automatically connect to teh vwlc, or so I am told.
Lots of questions here,
Cheers and thanks for your help!
EDIT: Just remembered, the AP is flashing green & red as well, although I'm not sure what that means, and i've given it plenty of power over POE (I think; its set to get up to 15400mWatts)
07-22-2019 05:01 AM
07-22-2019 05:42 AM
Where is that configured? On the AP or on DHCP server?
07-22-2019 06:22 AM
After creating a DHCP server via win server 2019, and adding rule 43, I now get these messages:
Translating "CISCO-CAPWAP-CONTROLLER.axtmann.ca"...domain server (1.1.1.1) *Mar 1 01:51:40.935: %CAPWAP-5-DHCP_OPTION_43: Controller address 192.168.5.113 obtained through DHCP Not in Bound state. *Mar 1 01:52:27.450: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP. *Mar 1 01:52:30.470: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.5.10, mask 255.255.255.0, hostname AP7081.05b0.f082 Translating "CISCO-CAPWAP-CONTROLLER.axtmann.ca"...domain server (1.1
As far as I can tell, it seems that the AP can find the controller, but It does not seem to want to connect for some reason? Any Idea why?
07-22-2019 06:36 AM
check the time on controller !
also paste the output of these commands:
sh sysinfo from WLC
sh version from AP
and complete bootup process from AP console.
Dont forget to rate helpful posts
07-22-2019 06:51 AM
vWLC output of show sysinfo:
(Cisco Controller) >show sysinfo Manufacturer's Name.............................. Cisco Systems Inc. Product Name..................................... Cisco Controller Product Version.................................. 8.1.120.0 RTOS Version..................................... 8.1.120.0 Bootloader Version............................... 8.1.120.0 Emergency Image Version.......................... 8.1.120.0 Build Type....................................... DATA + WPS System Name...................................... CISCO-CAPWAP-CONTROLLER System Location.................................. System Contact................................... System ObjectID.................................. 1.3.6.1.4.1.9.1.1631 IP Address....................................... 10.0.0.2 IPv6 Address..................................... :: System Up Time................................... 2 days 14 hrs 2 mins 29 secs System Timezone Location......................... System Stats Realtime Interval................... 5 System Stats Normal Interval..................... 180 Configured Country............................... CA - Canada --More-- or (q)uit State of 802.11b Network......................... Enabled State of 802.11a Network......................... Enabled Number of WLANs.................................. 1 Number of Active Clients......................... 0 Burned-in MAC Address............................ 00:0C:29:E6:AC:ED Maximum number of APs supported.................. 200 System Nas-Id.................................... h WLC MIC Certificate Types........................ SHA1
AP output of sh version :
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 15.3(3)JA7, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Thu 31-Mar-16 22:35 by prod_rel_team ROM: Bootstrap program is C3500 boot loader BOOTLDR: C3500 Boot Loader (AP3G1-BOOT-M), Version 15.3 [vtoky-imagetype 106] AP7081.05b0.f082 uptime is 5 minutes System returned to ROM by reload System image file is "flash:/ap3g1-k9w8-mx.153-3.JA7/ap3g1-k9w8-xx.153-3.JA7" Last reload reason: This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-CAP3502I-A-K9 (PowerPC460exr) processor (revision A0) with 98294K/32768K bytes of memory. Processor board ID FTX1534KDF0 PowerPC460exr CPU at 666Mhz, revision number 0x18A8 Last reset from reload LWAPP image version 8.0.132.0 1 Gigabit Ethernet interface 2 802.11 Radios 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 70:81:05:B0:F0:82 Part Number : 73-12175-05 PCA Assembly Number : 800-32268-05 PCA Revision Number : A0 PCB Serial Number : FOC15302H94 Top Assembly Part Number : 800-32891-01 Top Assembly Serial Number : FTX1534KDF0 Top Revision Number : A0 Product/Model Number : AIR-CAP3502I-A-K9 Configuration register is 0xF
07-22-2019 11:45 PM
