What is password after ap is taken out of WLC
wfqk
Level 5
Level 5
Hi AP1130 is taken out of WLC. when console is connected to it, it requires password. the password is not default password. and i do not want to password recovery. What password it could be? In WLC, we only has password for users to access wifi. i do not think the password can be used for this. Anyone has some suggestion? Thank you
2 Accepted Solutions
cmarva
Level 4
Level 4
it should be whatever the AP credentials are entered in the controller.
on your controller, select wireless>global configuration and you'll see the AP login credentials.
you'll see the username, but I don't know of any way to see the password, but maybe if you see the username it will be one of your standard credential pairs.
Correct, All AP will use new username/password.
Dont forget to rate helpful posts
cmarva
Level 4
Level 4
Sandeep Choudhary
As in other post mentioned..it is configured under global configuration page of WLC. If you forget it then only optoin to recover or change the password is to reset:
1. connect AP again to WLC for 5-10 min.
2. Reset the password on WLC (under global config page)
That means all APs under the wlc would use the new password, right?
