248
What to upgrade first for smooth Transition
We are trying to upgrade Prime, MSE and WLC to the latest code. But need to figure out what to upgrade first. Is there a procedure to follow? Checked the compatibility chart and Upgrade guides but did not find specific info. Please advice
2 REPLIES 2
Hall of Fame Community Legend
Re: What to upgrade first for smooth Transition
The Release Notes for each platform have detailed instructions on how to perform an upgrade successfully.
Highlighted
You have to check the release notes of the WLC, Cisco Prime and MSE, Based on that you have to take a decision.
Refer : Cisco Wireless Solutions Software Compatibility Matrix
For an example if you are upgrading your prime with 3.6 Code, your controller code support will be as per the Table 6 Cisco Prime Infrastructure and Cisco Wireless Release Compatibility Matrix based on the model of your WLC.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Content for Community-Ad
August's Community Spotlight Awards
