06-15-2012 12:02 PM - edited 07-03-2021 10:18 PM
I found 20Mhz bandwidth enable option in 2504 controller.But what about 40 Mhz .The access points(1142) are dual band...I hope it should support in 2504 controller also.If there is no option of 40Mhz ,Please Correct me
06-15-2012 03:42 PM
On all N APs it is supported only on 5Ghz(A-Radio) & not in 2.4Ghz(G-Radio). This feature is platform independent.
06-24-2012 11:29 PM
Just like what Sarvanan said, 40 MHz is only available on 802.11a (5GHz) and not on 802.11b/g (2.4GHz).
However, in old versions of code (6.0.182 or something like that) for wirleless controller I remember the 40 MHz was also available for 2.4 GHz (802.11b/g). They recognized later it is not feasible to add it to 2.4 GHz so they removed it from later releases.
Amjad
