09-09-2012 12:11 AM - edited 07-03-2021 10:38 PM
Dear All, Please advice me which controller I should use with 11 1552E AP ? I know 5508 will work with the AP's, but would the 2504 also work? If 2504 will work, I will go for the 2504 since its a cheaper solution. Please help me out. Thanks
09-09-2012 12:24 AM
Duplicate post #2.
It's not the question about the model of the controller. It's the question of the firmware.
Look at the Software Release Support for Access Points link which will tell you exactly which WAP can be supported by which firmware of the controller.
09-09-2012 12:30 AM
so 1550 series suuports
and the 2500 controller supports
2500 | 7.0.x | - |
so its compatible? does this also mean the 7.2 version of of 2504 is also compatible with 1552 ? beacause I have a 2504 controller with 7.2 firmware and I see only a 7.0 and 7.3 release for the 1552E series above.
09-09-2012 12:36 AM
What is the EXACT model of your 1552? Look at the matrix.
The 2500 can load any firmware from the 7.0.X up to the latest 7.3.101.0.
09-09-2012 12:38 AM
its a AIR-CAP1552E-E-K9 so its a 7.0.116.0
09-09-2012 02:27 AM
Correct.
