Which Controller to use for the 1552E outdoor AP ?
khan300
Dear All, Please advice me which controller I should use with 11 1552E AP ? I know 5508 will work with the AP's, but would the 2504 also work? If 2504 will work, I will go for the 2504 since its a cheaper solution. Please help me out. Thanks
5 Replies 5
Leo Laohoo
Duplicate post #2.
It's not the question about the model of the controller.  It's the question of the firmware.
Look at the Software Release Support for Access Points link which will tell you exactly which WAP can be supported by which firmware of the controller.
so 1550 series suuports
1550 Series
AIR-CAP1552I-x-K9
7.0.116.0
AIR-CAP1552E-x-K9
7.0.116.0
AIR-CAP1552C-x-K9
7.0.116.0
AIR-CAP1552H-x-K9
7.0.116.0
AIR-CAP1552SA-x-K9
7.0.220.0
AIR-CAP1552SD-x-K9
7.0.220.0
AIR-CAP1552CU-x-K9
7.3.101.0
AIR-CAP1552EU-x-K9
7.3.101.0
and the 2500 controller supports
2500
7.0.x
so its compatible? does this also mean the 7.2 version of of 2504 is also compatible with 1552 ? beacause I have a 2504 controller with 7.2 firmware and I see only a 7.0 and 7.3 release for the 1552E series above.
What is the EXACT model of your 1552?  Look at the matrix.
The 2500 can load any firmware from the 7.0.X up to the latest 7.3.101.0.
its a AIR-CAP1552E-E-K9 so its a 7.0.116.0
Correct.
