10-03-2019 07:03 AM - edited 07-05-2021 11:05 AM
Hi Wifi 3G/4G/5G are 3/4/5 generation. while a/b/ac/ax are different band respectively. My question is what is relation between 3G/4G/5G and a/b/ac/ax? Thank you
Solved! Go to Solution.
10-03-2019 03:43 PM
10-03-2019 07:08 AM
- You may find an example response below :
https://www.quora.com/What-is-the-difference-between-WiFi-and-GSM-or-LTE
M.
10-03-2019 03:43 PM
10-03-2019 08:50 PM
