wifi client information
wyfy-2015
Is there a way to get client detailed information
like whether it supports  MIMO  how many RX ,TX antenna and  spatial streams it support from the wlc .
If not from the client  like windows ,mac ,ios  and android devices like
Scott Fella
You can get some data from the RF Dashboard of the WLC. That is if you are running v8.1 or newer.
As far as the devices, you need to get that from the manufacturer or the NIC vendor.
This might help also:
http://www.mikealbano.com/2015/01/wifi-client-capabilities.html?m=1
-Scott
I am using wlc 5760 .
The mcs index will help ?
If yes how to translate the mcs index
MCS is not going to tell you exactly what the device NIC is capable of. You need to look at the link I posted or look at specific device data-sheets.
-Scott
