06-08-2015 02:03 AM - edited 07-05-2021 03:21 AM
I have the RV110W running ver 1.2.1.4, Firmware MD5 checksum:9db70c4be4a4377bfdef5e3d398214d8. It allows for a 75 security key to be entered in the Wifi section for an AES WPA2 configuration.
Isn't the standard 63 character?
06-08-2015 08:54 AM
Yes You are right its minimum 64 characters.
Please find the below file for more info about the Cisco RV110W
www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv110w/administration/guide/rv110w_admin.pdf
06-09-2015 04:52 PM
06-23-2015 03:17 AM
I enter a 63 or 64 wifi password on the RV110W however when I go to make the password visible and copy it to a tet document the password is changed and greater than 64 characters it can be anywhere from 68 to 75 charaters long.
06-19-2015 02:54 AM
As per my understanding, it should allow maximum of 64 characters, if it is allowing more than 64 character it could be a bug in this release upgrade it to latest code and then check.
well what is you actual issue ? are you facing any error while setting up a password.
