220
Beginner
WiFi WLC Web Portal Sucks
Does anyone have any suggestion on how I can resolve this issue? When logging into web portal of cisco wlc, it sometimes loads or half loads or errors out. WLC.PNG
Everyone's tags (1)
8 REPLIES 8
Highlighted
Rising star
Re: WiFi WLC Web Portal Sucks
 - Have you tried different browsers (sometimes also certain brands of browsers are supported only). ?
   M.
Beginner
Yeah I have tried multiple browsers. IE seems to work the best but still crashes/doesn't load. I wonder if there are settings that need enabled in the browser settings for this it work better? The internal site is added as trusted on each browser.
Enthusiast
I had the same issue after I turned on HTTPS redirect.  Once I turned it back off the issue resolved itself.
Management/HTTP-HTTPS: HTTPS disabled.
VIP Advocate
This and maybe your WLC needs a software update. Which version are you running?
Beginner
8.3.133.0
Beginner
Yeah it is horrible.
VIP Advocate
Ok, in that case I suggest you upgrade to 8.3.150.0. There were several web interface bugs resolved since 8.3.133.0.
Or even better, 8.3.15x.x TAC Escalation build, which you only get by contacting TAC.
See here for more information: https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Beginner
I agree, sometimes when you have to make a single change on an access point and you open the list and it doesn't load.  Then you press F5 and it does load, then you click the individual AP and it fails to load again so you press F5 again but you're back in the list view, all filters gone...
Everyone's tags (2)
Content for Community-Ad
August's Community Spotlight Awards
