Community Helping Community
488
Beginner
Will adding a new AP to existing AP Group cause all AP's in group to reboot?
Hi Guys
Looking to deploy a new AP to vWLC controller, want to make sure I dont effect any users.. will adding a new AP to existing AP group cause all the AP's in group to reboot or only the new AP being added.
Kind Regards
3 REPLIES 3
Rising star
Only the new access-point
Only the new access-point will be restarted.
Before you add the access-point to the correct group, the access-point by default will be placed in the default-group where WLAN ID 1 - 16 will be available with all the WLANs in the native VLAN of the access-point. Only this could give some impact if a client is nearby the new access-point and will roam to it. Don't forget to push the correct VLAN ID's with a FlexConnect group or just configure them static on the AP itself.
Rising star
It will only reboot the new
It will only reboot the new added AP not the entire existing AP group.
Highlighted
It will not reboot the whole
It will not reboot the whole group when you edit/add AP in the group.
Correclty AP reboots only if there is a change to its 'AP mode' , 'AP Group' or 'HREAP Group'.
Content for Community-Ad
August's Community Spotlight Awards
