08-07-2020 05:27 AM - edited 07-05-2021 12:22 PM
hi everybody
i have tested wired guest lan with one C9800 Foreign in the LAN and one C9800 Anchor in the DMZ.
12-16-2020 05:47 AM
I was also looking for, but unfortunatelly i didn´t find anything regarding wired guest with c9800. So we just let the old 5520 WLC Controller for Wired Guest Authetification.
In C9800 i found that there are some Wired Guests Commandos like guest-lan profile-name .... Maybe you can configure it by yourself.
12-16-2020 10:54 PM - edited 12-16-2020 11:05 PM
up to the recent 9800 code 17.4.1 the Wired Guest solution is supported only with Foreign/Anchor scenario, maybe this will be changed in the future releases.
Note: 9800 and AireOS WLCs in Foreign/Anchor scenario is supported as well as any combination of 9800 appliance and virtual controllers.
04-01-2021 07:25 AM
Hi Grenzider
Can I use C9800-CL (virtual) at least for DMZ Anchor ? Or is HW C9800 mandatory ? If virtual C9800-CL is permitted, what kind of license do I need ?
Ondrej
04-01-2021 08:47 AM
Yes, 9800-CL "private cloud" is supported as Anchor WLC and you don’t need any license on the Anchor unless you will connect APs to it.
