03-07-2014 11:20 AM - edited 07-05-2021 12:22 AM
Good Morning
Actually I have some AP`s (1130) in my central office and other in remote office. I use a wireless device called Handheld (Motorola) to download an archive .cab but when I try to do this from server located to central office, it get to interrupt the connection for some reason. However in some remote office do not happen the same behavior. Routers in remote offices are connected throught ME and PPP connection. As a backup link I have an easy vpn connection. I did these tests and activities:
- I had to shut down interfaces (serial or ethernet) to flow traffic throught easy vpn. With this test I am sure that this type of traffic is not falling in default class.
-I upgraded WLC 5500 to 7.4.121.0 because I thought it was a bug in firmware 7.0.235.
-I reviewed bandwidth in WAN connection.
Did you happen this case in the past?
03-07-2014 11:39 AM
Hi Richard,
If you could provide us "show client detail
7.4.121.0 is a recommended version & good to see you with that code.
Rasika
03-07-2014 11:57 AM
(Ftd_WLC_1) >show client detail 00:15:70:a8:90:90
Client MAC Address............................... 00:15:70:a8:90:90
Client Username ................................. HH_Cuartel_2
AP MAC Address................................... 00:1f:ca:83:c3:90
AP Name.......................................... AP_Cuartel_2
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 00:1f:ca:83:c3:91
Connected For ................................... 44 secs
Channel.......................................... 1
IP Address....................................... 10.105.0.92
Gateway Address.................................. 10.105.255.250
Netmask.......................................... 255.255.0.0
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... No CCX support
Re-Authentication Timeout........................ 86334
QoS Level........................................ Silver
802.1P Priority Tag.............................. 2
--More-- or (q)uit
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
APSD ACs....................................... BK BE VI VO
Power Save....................................... ON
Current Rate..................................... 36.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
............................................. 12.0,18.0,24.0,36.0,48.0,
............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. c0a801640000c560531a209b
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Client Type...................................... SimpleIP
PMIPv6 State..................................... Unavailable
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
--More-- or (q)uit
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... EAP-FAST
Interface........................................ hhtiendas
VLAN............................................. 105
Quarantine VLAN.................................. 0
Access VLAN...................................... 105
Client Capabilities:
CF Pollable................................ Not implemented
CF Poll Request............................ Not implemented
Short Preamble............................. Implemented
PBCC....................................... Not implemented
Channel Agility............................ Not implemented
Listen Interval............................ 20
Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
WFD capable................................ No
Manged WFD capable......................... No
Cross Connection Capable................... No
--More-- or (q)uit
Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
Number of Bytes Received................... 79472
Number of Bytes Sent....................... 89767
Number of Packets Received................. 770
Number of Packets Sent..................... 429
Number of Interim-Update Sent.............. 0
Number of EAP Id Request Msg Timeouts...... 0
Number of EAP Id Request Msg Failures...... 0
Number of EAP Request Msg Timeouts......... 1
Number of EAP Request Msg Failures......... 0
Number of EAP Key Msg Timeouts............. 1
Number of EAP Key Msg Failures............. 0
Number of Data Retries..................... 463
Number of RTS Retries...................... 70
Number of Duplicate Received Packets....... 17
Number of Decrypt Failed Packets........... 0
Number of Mic Failured Packets............. 0
Number of Mic Missing Packets.............. 0
Number of RA Packets Dropped............... 0
Number of Policy Errors.................... 0
Radio Signal Strength Indicator............ -78 dBm
--More-- or (q)uit
Signal to Noise Ratio...................... 16 dB
Nearby AP Statistics:
AP_Cuartel_1(slot 0)
antenna0: 23 secs ago.................... -82 dBm
antenna1: 23 secs ago.................... -79 dBm
AP_Cuartel_2(slot 0)
antenna0: 23 secs ago.................... -80 dBm
antenna1: 23 secs ago.................... -78 dBm
DNS Server details:
DNS server IP ............................. 180.185.1.19
DNS server IP ............................. 180.185.1.18
Assisted Roaming Prediction List details:
Client Dhcp Required: False
03-07-2014 12:12 PM
Hi Richard,
As you can see devices is having -78dBm RSSI which is not that strong, indicating device is far from the AP. It is connected 36Mbps at the given time on CH1.
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,12.0,18.0,24.0,36.0,48.0,
Is it possible to do a test with the device is closer to a AP & see still problem occurs. Also I would suggest disable low data rates 1,2,5.5,6,9,11 on your WLC 802.11b/g/n & 802.11a/n bands. That should help improving the overall performance on your wireless.
Rasika
**** Pls rate all useful responses ****
03-07-2014 12:26 PM
Hi Rasika
I checked these values in my WLC and all of them are disabled, I referred support rates. By the way I did a test take my wireless device closer an AP and this has the same behavior.
03-07-2014 02:20 PM
Look at the show client detail and what is the RSSI value? Test with a laptop on the same SSID and test file transfers or use iperf.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
03-08-2014 05:58 PM
03-07-2014 03:03 PM
Richard,
You said that the other site(s) have no issues? Are the APs from the other site(s) coming back to the same controller or to another controller?
03-08-2014 05:53 PM
